AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread
*Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread - Page 16
post #451 of 1713
From what I read, those ML speakers are difficult to drive because of their capacitive nature. The best amp for them are tube amps.
post #452 of 1713
I have a question for anyone who might know. If I set the HDMI for pass-through (but let's say the last source I used before I turned off the 1522 was my BD player), then if I want to just watch TV through my Dish Hopper with the Receiver turned off, what setting needs to be made on the 1522 so that I can use the TV/Hopper combination without having to turn on the receiver to change the input from the last-used BD to Sat/CBL? I'm sure this is an easy fix, I just can't seem to figure it out.
Thanks in advance for your help.
post #453 of 1713
RE: *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread
There isn't any way
Sent from my RM-820_nam_canada_246 using Board Express
post #454 of 1713
Just bought this at my Costco in Bellingham. They have plenty there and have had them for weeks if any one in the NW needs one.
My problem is I have a computer plugged in. I can get the video perfectly well. We can't get the sound. The PC is plugged in via HDMI but has separate optical digital out. We have plugged this into both Opt-1 and Opt-2 and assigned to the input the HDMI input the computer is connected to and no luck. I tried the digital coax and still nothing. I even plugged the audio in from the headphone jack to RCA's on the receiver and no sound. The setup on the computer is correct and this setup worked perfectly on the Onkyo I am replacing. I tried several digital cables, they all have the red light on when I plug into the receiver. I've gotta be missing something. any ideas? I see the sound on the computer playing and the "meter" so I know it's working.
thanks.
post #455 of 1713
thanks.
Hi f1snob, on the remote use "Signal Sel" and set to Digital.
post #456 of 1713
Originally Posted by Foxbat121 View Post
There isn't any way
I thought I remember reading somewhere in the manual that all you had to do was to press "a" button on the remote (not sure which one), with the receiver still off mind you, that would allow you to switch the source input without having to turn the receiver on. Maybe I just dreamed it...
post #457 of 1713
f1snob, this is needed. the default is auto and the priority in audio signals for each input is HDMI > Digital > Analog.
post #458 of 1713
I find it interesting that nobody has yet written a review of this receiver for the reviews section
post #459 of 1713
There isn't any way
I think I may have found an answer to my question. On page 66 of the manual, Item #8, it reads as follows:
8 Select the ‘Standby Through’ setting you want.
It is possible to transfer signals from an HDMI-connected player to the TV when this receiver’s power is on standby. Select the HDMI input whose HDMI signal is to be input for through transfer when in the standby mode. When LAST is selected, the signal being input to the currently selected HDMI input is transferred. When OFF is selected, no HDMI input is transferred through when in the standby mode. (However, when Control is set to ON, the HDMI signal is transferred through by the Control with HDMI function even when in the standby mode.)
  • When anything other than OFF is set for this setting, the receiver’s HDMI input can be switched even when the receiver is in the standby mode. (Switch by pointing the remote control at the receiver and pressing the HDMI, BD, DVD, SAT/CBL or DVR/BDR button.)
  • This setting can be used even with devices that are not compatible with the Control with HDMI function.
  • Setting to anything other than OFF increases power consumption in the standby mode.
I knew I had read this somewhere in the manual, but I just couldn't remember where I had read it. Hopefully this will help others address this capability, too.
post #460 of 1713
In the manual: pg 66, item 8, 1st bullet.
All you need to do is make sure your HDMI select is set to anything but off and you can change inputs via the remote while the receiver is in standby.
post #461 of 1713
Looks like you beat me by a minute.
post #462 of 1713
That's quite alright PE. Either way I would have gotten my answer. Thanks for your help.
post #463 of 1713
Two questions...did yours have an owners manual in the box? I can hear slight transformer hum with my ear pressed to the top, but not probably 2-3 feet away. How loud has the hum been for the people that have decided to exchange theirs because of hum?
post #464 of 1713
That's correct. You don't need a new sound-card. Just a video card with HDMI.
Are you sure that will do 5.1 for games? I have that but the HDMI cable isn't long enough to test easily. I'll have to move stuff around and try it.
post #465 of 1713
No owner's manual in the box, one of my big complaints on a "$1,600" (MSRP) product! I copied mine. It didn't use too much ink and FedEx spiral-ring bound it for me in landscape for about $9 with nice covers fore and aft. I find this easier to use, especially when flipping back and forth on a subject. The print, especially the very light blue used on the links (which are still helpful in a printed manual) will severely tax older eyes. Sometimes I have to revert to the two-pairs-of-glasses method. Definitely use "highest quality" on your printer if you do this.
No hum on mine. I've hung around jet engines so long I'd be happy to hear it!
post #466 of 1713
HDMI is capable of 7.1 LPCM output. As long as your game supports it (which is the question for individual games), there shouldn't be a problem.
post #467 of 1713
Anyone in Jersey know of a Costco that still has any in stock???
As fortune would have it, my Pioneer SC-35 just crapped out. Shuts off in seconds of power on, ipod light blinking. I got it from costco almost 2 years ago in a similar deal as this. Yes, costco took it right back, no questions, full refund. So, I'm looking at a new A/V receiver, wondered whether to pay for the new SC elite (61/63/65) and noticed the SC-1522/1222 designation on the "regular" Pio a/v receivers. Wondered why a non-elite receiver would carry an SC designation in its model name. Noticed it spec'd out the same as the SC-65. Started searching...and came here.
Looks like i'm maybe 2 weeks too late, but again anyone in the Jersey (NYC to Philly, Atlantic Ocean to Eastern PA) area know where any are left?
-C
post #468 of 1713
-C
COSTCO in Ocean had at least 8 of them as of last Tuesday
post #469 of 1713
Costco in Edison has 14.
post #470 of 1713
-C
Try the Costco in Comack on Long Island. Had a few last week.
post #471 of 1713
I would highly recommend that you call the store to make sure they have a non-display model in stock and that they're willing to hold one for you.
Nothing worse than making a 2+ hr car trip and dropping $25 just in bridge tolls just to find out they sold the last one only 5 minutes ago.
post #472 of 1713
I've seen Sony TVs with a MSRP of $4100 with no printed manual in the box. Your options were to use the digital manual that was built-in to the tv or use the electronic one on their support website.
Unfortunately more and more companies are trying to save money by not having to print them. It's just the way things are going, especially since most users won't even read them or will just reference a few pages.
People today just want it to be plug & play.
When was the last modern electronics item you bought that actually came with a manual? Just to name a few, my iPad, 3D blu-ray player and smartphone all skipped the manual for a quick-setup pamphlet.
post #473 of 1713
I miss manuals too... until I read things like the 1522's, which is as bad as my old VSX-919's. They've learned nothing. I've saved the manual as an iBook and bookmarked pages. Ideally, I prefer printed but realistically the searchable, bookmark able PDF is handier.
Now, if other manufacturers wrote their manuals as clearly, succinctly, and customer-friendly as Oppo then I'd miss them more. It's the first electronics manual in twenty years that actually simplified everything and answered questions before I had them and *gasp* anticipated my follow-up questions immediately or with excellent cross-referencing.
post #474 of 1713
-C
No North Jersey stores have them, but the central Jersey stores have them. I bought mine in Edison three weeks ago (a 45 minute ride that turned into an hour+ when I got lost in Perth Amboy), and I called them yesterday for kicks just to see if they still had them. They had 17 at the time (they had 9 left when I bought mine, so they must've gotten a refill).. Bridgewater had several a few weeks ago when I called them too.
It's very strange how the central Jersey stores are actually getting replenishments of this item while there are none to be found in North Jersey.
post #475 of 1713
Originally Posted by Yo View Post
I saw this receiver at COSTCO a couple of weeks ago and googled it and came upon this thread, which gave me an idea, what kind of a gem this receiver can be, in particular at the COSTCO price and warranty. So I jumped on it last week and replaced my Yamaha 4065(also COSTCO, unfortunately more than 3 months old frown.gif). In the past I have had "real high end equipment", and my speakers are still very good, but I have replaced most of it for the convenience of being able to use HDMI switching and other conveniences of the digital age. Still this receiver sounds very good, I in particular love the ability to bi-amp my Snells, even though they don't require much power to "sing", they sound quite a bit better (more open, wider more defined sound stage and better bass as well as mid range). The THX certified AV processor is simply awesome, definitely for the price.
A couple of smaller(to me) issues:
1 - No on-screen display during play-back: I seem to remember that there was a volume control on the screen when I first fired this receiver up. I since performed the firmware upgrades and no matter how I set the OSD settings (on/off) in the set-up, there is no volume or source information on the screen...
2 - Fan noise: The receiver is on a rack in the room about 11ft away from listening position. It gets warm though not hot, and the fan kicks in, which I can hear. It does not bother me yet(I mostly watch TV or movies), but it is one of those noises that when its off you notice that it was there.
Any advice on above items is appreciated
Great Thread - very helpful keep it going
1.) - Make sure you have the display plugged into HDMI out #1, the OSD will not show on HDMI out #2.
Someone else on the fan noise?
post #476 of 1713
Originally Posted by jamjam View Post
Anyone that is using the Pioneer Sc-1522 just for home theater, radio, internet radio, listening to music and video through your PC-are you having any problems? How does it sound/perform compared to what you had?
I'm using it for all this too, and it's seamless. Coming from Denon 2113, the sound is great. The 9.2 is priceless as I have 7.1 + Zone 2 Patio. The only issues I have really is the amount of time it takes to switch from one input to another. It's a good couple seconds in between, also this lag is annoying when trying to get into and out of the setup menu. The Android app is phenomenal compared to the Denon, but it has the same issue where every time you load the app it seems to need to "re-find" the receiver, which is annoying... There is a 3rd party app that keeps the connection constantly I paid a few $'s for, but it lacks some other features. Still trying to get my Harmony One remote dialed in on some specifics- haven't been able to fully understand or program the hex codes to program a Pandora "activity", but once I figure that out it should be golden!
post #477 of 1713
It was two weeks ago when I bought an Oppo BDP-103 with an 86 page bound manual. It only cost $500 and I think Oppo is doing OK. The box they sent it in compares to Apple products and the unit itself was in a cloth bag to keep it from scratches. I don't care what the lowest common denominator wants. A product like this should come with a book without demanding computer games at each phase.
IronWaffle is right. The Oppo manual gets you there. If Pioneer can't write one at the level of their electronics they should hire an off-duty soldier in Japan with a background in electronics and English, not hard to find, and run him through a course in how the equipment works. In America, every new product that is released is soon followed by an unofficial "Book They Should Have Included" that we all buy. We aren't that lucky in the home theater game.
Edited by alnilam1 - 4/21/13 at 5:44pm
post #478 of 1713
Need some major help...
I have a Mistsubishi LED TV that has a built-in sound bar to the tv. It has 12 tweeters essentially in the sound bar attached to the tv and has a Center Channel Input on the back of the tv with a male rca connector. This TV has always sounded great without speakers and given the new location of the tv (over the mantle flush on the wall) I am left with no room for a center channel.
I was under the impression that I could set my tv's speakers to "center" and use a male rca to male rca connecting one end to the Center Channel Pre-Out on my 1522k receiver and the other end to the rear of the tv.
So far I can not get this setup to work. MCACC is not running sound through the tv and I can't seem to manually make it work. What settings am I missing? Is this not "doable" even though the tv was designed to act in this function?
Also I have 2 fronts, BIC FH-65b's and two ceiling mounted rear speakers.
MCACC was able to send sound to the fronts and the surround speakers but when watching movies I can not get sound to come out of my rear speakers. The front of the receiver only shows "L" and "R" as active speakers, not any surrounds, help on this as well please!
Thank you for everything, please help me figure this out!
post #479 of 1713
Thank you so much - that was it !!!! I kind of thought it would be something simple. Did not look up the orientation of the output jacks(that's where at least a basic manual would have come in nicely), just assumed they ran the same direction as the inputs - duhhh.
No I can certainly hide this receiver in a closet behind my TV.
post #480 of 1713
-C
Makes me a little worried about the longevity of this product hearing this about a former "SC-" model. Even the manual indicates that when the iPod light is blinking, it's time to call a Pioneer serviceman. Sure hope that doesn't happen to mine. Anybody still own a first generation SC- model that's still running and, if so, how old is it?
