AVS › AVS Forum › Audio › DIY Speakers and Subs › Triple Gjallarhorn + Othorn Build
Triple Gjallarhorn + Othorn Build - Page 4
post #91 of 163
Originally Posted by Bassnectar View Post
Still have a fair amount of work to do on it, but the B&C is on its way biggrin.gif
You ordered it?! Excited to see it.
post #92 of 163
Two ready to paint:
Just waiting on Fedex for my Duratex and second LMS today.
post #93 of 163
I couldn't grasp the size of those boxes until the LMS was next to it. eek.gif
Holy Smokes Batman!
"A little coffee with my sugar. Why, Yes my Queen. Chip chip!"
"Those aren't boxes, those are Ultra's, surrounded by rain forests." tongue.gif
post #94 of 163
Haha indeed. I didn't grasp the weight until they had to go down the stairs....
post #95 of 163
I just got a email saying mine are done!! I'm not looking forward to putting those in the basement!!!! Better eats me spinach!!
post #96 of 163
Nice! I'm in hog heaven over here with two of these things!!
post #97 of 163
Two coats of Duratex on and the inside blacked out! Will do a third tomorrow morning and then it's time to fire them both up!
post #98 of 163
OMG!!
is that the room they are going in? it doesnt look very big. im scared for your house!! eek.gif
post #99 of 163
Originally Posted by brian6751 View Post
OMG!!
It's about 14x25x7.5 so no not too big.
How do you like the Cornscala's? I might build some of those next so I can cross the Ghorns off at 60hz.
post #100 of 163
Three coats done. Just gotta do the bottom side.
post #101 of 163
they are great speakers, but not cheap. over $1200 just for the components and Bob's nice cross overs. They sound awesome and can get very loud with very little power. no sub needed for music. make sure to also look at the SEOS Sentinel or the SEOS 15 / TD15. these might be a better bang for your buck with your sub system.
i have been wondering what something like the Sentinel or that TD15 combo in a Cornscala sized cabinet would be like.........
post #102 of 163
I'm that guy that never paints the bottoms of his subs lol. It part being lazy and part with the bottoms painted, it's extremely hard to slide them on the carpet once done.
Our rooms are really similar in size. I will be picking mine up Tuesday next week. I'm really looking forward to see what you think in your room! I know it's going to be pretty insane but HOW insane is what interests me. As of now, I'm 136dB @ 15hz, I'm hoping these will actully be able to blow a chicks dress off biggrin.gif
post #103 of 163
Is the Duratex easy to apply or is it a pain?
post #104 of 163
EASY to apply. Roller and roll it on. Simple as that. Clean up is water.
post #105 of 163
If you can roll on paint, you can paint with duratex. It's super easy!
post #106 of 163
Yea I'm interested in the options. I already have the SEOS 12 with the Deltalite driver for front three. I could eventually build a fourth of those and use them as surrounds and then build some SEOS 15's or Cornscala's for the front three.
Super easy. Get a foam roller from Speaker-hardware. Gives a really nice texture and makes it really easy to apply. Just put a thick but even first coat that seals it completely and then add coats for desired texture. Dries really quick and cures rock hard. Can take a screw driver to it once it's fully cured and won't do a lot.
Driver in:
Hatches fit nicely!
In front of the screen. I think this will measure well but I'll get to that tomorrow and play around with positioning a bit.
If I put them like this I would slide them the 28 inches back against the wall / under the screen and the other foot and a half would be peaking out.
post #107 of 163
Holy ****!!!!
My DTS-10 sucks compared to one of these.... Will get both running in a bit!
post #108 of 163
wonder if you could try coupling the mouths together like this:
post #109 of 163
IIRC a tapped horn doesn't act like a normal horn. Placing the mouths together doesn't net +3db in efficiency, nor a -3hz lower f3.
post #110 of 163
post #111 of 163
I'm also not too worried about output, more smooth response. Also having them together with the mouth out will put the mouth about 1/4 into the room on each side. With just one sub both of were pretty smooth before. May also do one in front behind screen and one behind seating.
Any recommendations / thoughts?
Originally Posted by KyleLee View Post
Thanks! I think they turned out rather well :-) Big thanks to Ricci for the design / help and luke for his informative thread.
Edited by dsl1 - 4/21/13 at 5:23am
post #112 of 163
Who said that and why not, the law of physics is the same for sound waves, I have two Tapped Horns and whith the second one have got +6dBs by measuring at LP smile.gif
post #113 of 163
ds|1
Your craftsmanship has inspired me! I have two 3cf custom built aperiotic vented subs. Just upgraded the plate amps. The 20 yr. old (thanks to rubber surrounds) AudioConcept 12" subs still rock. I'd like to redo the boxes. Can I roll Duratex over existing latex satin black? Should I sandpaper scratch the existing finish first? Looking forward to seeing your listening/measurement tests post.
post #114 of 163
I have seen many other people use satin black as a first coat and then use Duratex over that. All looks fantastic and seems to perform just as well. I will be doing the same next time to save on coats of Duratex.
post #115 of 163
Originally Posted by sgibson View Post
ds|1
Yes that will work great. Duratex is really thick and will go over just about anything. I've done the same and it's come out looking very good.
post #116 of 163
I've read it on more than one occasion over at DIYAudio. I had always assumed it had to do with the fact that a tapped horn uses the drivers back wave. I hope I'm wrong about it... four of these guys stacked would be flat to ~10hz with ridiculous output and admirable efficiency.
post #117 of 163
I've been thinking about placement options as well.
When I get the Othorns built, there's not going to be any space for them up front. I think I'll try moving the GHs to the back of the room and see how that works.
post #118 of 163
Back wall 18" away from the corners and then have your Othorns in the front placement. Sounds like a plan for maximum spl. biggrin.gif
post #119 of 163
Updates:
Sounds great so far. Need to play with room placement and actually EQ. Right now just running Ricci's base EQ + Audyssey is set to whatever my DTS-10 needed with the exception of levels being set. Playing with positioning is a pain as they weigh approximately one million pounds and I have to pull down some of the false wall to get them behind the screen without knowing if that position is even going to work.
Music is phenomenally clean and powerful. Watched Black Hawk Down and the power is certainly there, just needs EQ for sure in my room.
Edited by dsl1 - 4/22/13 at 9:02am
post #120 of 163
Updates:
Great to hear you love GHs an 18 incher and low THD is clean and powerful sound with lots of details that is why I love Tapped Horns too smile.gif
