AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Help Me Design This VERY Modest Build
post #1 of 3
New to us home with a great 3.5 season room where we are going to put the "family room" until we finish the basement with a dedicated theater. Ive done some rough blueprint ideas (terribly, on ms paint lol).
I decided on a Samsung UN55EH6000 55" LED tv. I am looking a low, wide black TV stands. I plan to put the TV on the wall and everything else in the stand. ATM I have a receiver with an old Infinity TSS-450 surround setup on stands (minus the center channel)
We have a chaise lounge with wrapping couch, so Im thinking the best way is to corner it. The only downside is that the TV goes on a shorter wall, opposite two windows. I am getting top down bottom up shades for the windows to reduce glare etc.
...Equipment... (most of these have not been purchased yet)
Samsung uN55EH6000 55" LED
http://www.bestbuy.com/site/Samsung+-+55%26%2334%3B+Class+(54-5/8%26%2334%3B+Diag.)+-+LED+-+1080p+-+120Hz+-+HDTV/4834412.p;jsessionid=AB3533C622D28DD3FF77FD084DCCAF70.bbolsp-app02-162?id=1218540193959&skuId=4834412&st=un55eh6000&cp=1&lp=1
Cheetah Flush/Tilt Mount
http://www.amazon.com/Cheetah-APTMM2B-Including-Ethernet-Magnetic/dp/B0012S4APK/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=GA3AS41ZFSQ7&coliid=I10YB7ACCYX50P
Denon AVR 1513
http://www.crutchfield.com/p_033AV1513/Denon-AVR-1513.html
Polk TL1 Center Channel
http://www.crutchfield.com/p_107TL1CC/Polk-Audio-Blackstone-TL1.html
Infinity TSS-450 surround system (already Owned)
http://www.crutchfield.com/S-O7wXnqMQIpQ/p_108TSS450C/Infinity-TSS-450-Charcoal.html
Sony ps3 (already owned)
Potential TV Stands
http://www.wayfair.com/dCOR-design-Naples-60-TV-Stand-OQ-2719-XSN1024.html
http://www.wayfair.com/Tvilum-Metro-74-TV-Stand-7954261-7954249-TK1911.html
http://www.wayfair.com/Tvilum-Bradford-67-TV-Stand-7891520-TK1857.html
http://www.wayfair.com/dCOR-design-Holland-59-TV-Stand-ID-6601-XSN1072.html
http://www.wayfair.com/dCOR-design-Bromley-60-TV-Stand-CY-7121-XSN1003.html
http://www.wayfair.com/dCOR-design-60-TV-Stand-F-1179-CH-XSN1131.html
http://www.wayfair.com/Nexera-Sereni-T-60-TV-Stand-210406-QB1741.html
http://www.wayfair.com/Wildon-Home-%AE-Tehachapi-62-TV-Stand-811756-CST1707.html
The Chaise Lounge
...Room reference...
My thinking...
Pictures of the room (with the seller's furniture etc)...
What Are Your Thoughts On Furniture Placement?
What Are Your Thoughts On Equipment Selection?
What Are Your Thoughts On Colors for Painting Walls?
Constructive Suggestions for anything?
Edited by irishiron - 3/28/13 at 11:49am
post #2 of 3
Your equipment selection seems fine. Will you be upgrading the other speakers as well or just the center?
I prefer the first stand--the Naples. Although it's easiest to paint beforehand (i.e., before installing everything), I find that it's better to pick furniture, live with it for a while, then choose a paint color.
post #3 of 3
Undecided on the speakers. We will have an unfinished basement that we will build a more dedicated theater. I need a new receiver anyway, but could probably leave the rest for now.
