AVS › AVS Forum › Audio › Home Theater In A Box › Looking for home theater system
post #1 of 4
Hi guys I am looking for a decent home theater system for around $400 or there abouts.
Any recommendations would be really helpful.
Thanks in advance
post #2 of 4
Not getting any help here so will try elsewhere.
Thanks again..
post #3 of 4
Try Newegg, they have a special on a 7.1 system that is THX certified. Onkyo HT-S9400THX. Retails for $1099.99 and is on sale $599.99 through tomorrow. Know it's a little more then your looking to spend but it's a very nice system for a great price.
post #4 of 4
Accessaw believe it or not there have been people before you looking for a 400 dollar HTiB system. to find the most information I would search here for just that.
But to give you a preview (letting me do the work for you) check accessories4less.com if you are ok with refurbished, or you can check craigslist if you are up to a lot of research because you will never find exactly what you are looking for but could find something nice that you never thought of (this doesn't sound like a good option for you as you seem reluctant to do your own research and maybe a little bit impatient...). Or you could go down to best buy and listen to some systems and decide for yourself what sounds best to you (the best option and it will probably be done in one day).
Good luck
  Back to Forum: Home Theater In A Box
