AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Nad T757 speaker zone 2
post #1 of 2
I have bought a Nad T757 and i must say .. great system !
Just can't to figure out the folowing problem.
I want to connect outside speakers to the nad through the Zone 2 output so i can listen to the radio outside en others can watch a movie inside ..
I have a speaker cable running from in to outside but can't seem to connect this to the nad .. the only connection i can find for zone 2 is rca
Anyone suggestions ?
Greetz,
Dave
post #2 of 2
Look in the manual and the on screen setup. My T775HD allows me to assign the surround back channels to zone 2 but that will only leave me with 5.1 for the main zone. Do you have 7.1 in the main zone or 5.1. Also, double check if you can do the same thing I did on your setup. If you cannot then you will have to buy an amp because NAD is providing only preamp level output for Zone 2.
