AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can't access Dolby PLII Music or other music modes!!
post #1 of 4
Hi, I've had the 7007 for a couple of days and I love it so far. However, I cannot, no matter how many menu selections I've made, get the thing to play Pro logic MUSIC or any other sound field. I can click on Dolby PLII movie, but no music mode. Surround Parameters is highlighted but there are no choices other than Home Theater EQ on or off. It's Saturday so I can't call Marantz. This is really starting to piss me off. Why is this buried??
Any help would be great.
post #2 of 4
Okay, thanks to Matt at Magnolia in Webster, I've been able to access the menu. I can't find this in the owner's manual but apparently you press and HOLD the Music button to bring up a drop down menu. This doesn't seem intuitive at all but at least I found it. It says to press the button on page 77...I pressed it. It doesn't say HOLD until the menu comes up. This kind of thing can drive a guy crazy.
But, I will say this 7007 sounds really clean and smooth with my B&W 603 S3 speakers and surrounds. The bass to my SVS sub is tight and clean as well. Blows my previous Denon away.
post #3 of 4
An addendum that may (or may not) be of interest to some is that i programmed a Harmony Remote 670 with the music and movie buttons, but holding it down on the Harmony apparently doesn't have the same effect. At least for me, on the 6007. I need to use the remote that came with the Marantz to change the music and movie modes.
post #4 of 4
p. 75 Owner's manual ....
The 7007 uses the more advanced version of Audyssey MultEQ XT vs. only MulTEQ on your old 2307.
Also note there is a dedicated thread for 7007 Owners where you may find more helpful information .....
http://www.avsforum.com/t/1420942/marantz-sr7007-av-receiver-owners-thread/0_100
