AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › which is better dual sub or single sub
which is better dual sub or single sub - Page 2
post #31 of 37
Originally Posted by Splicer010 View Post
eek.gif Exsqueeze me? 2 1200's will hands down beat that klipsch in every way. Make no mistake as the OP knows this already, the 1200 is not to be discounted as a no name offering. Quite the contrary...Quality can and is had daily for less than paying for the moniker.
post #32 of 37
Okay. And you base you above on what metrics when comparing amplification, depth of reach and +/-3dB frequency response?
post #33 of 37
Guys guys, unless he's trying to combat sub localization, what's wrong with getting the 12D and pairing it with the 1200? confused.gif
post #34 of 37
Personally, as long as one has room analyzing capabilities and the subs are complimentary to each other, there's nothing wrong with mixing and matching subwoofers because with room analyzing capabilities, one will know exactly where they stand in the sonic chain of it all.
post #35 of 37
WHICH one is better energy esw c10 or bic f12? same with 150 bucks used.
Edited by caloyzki - 4/3/13 at 7:39am
post #36 of 37
Thats a no brainer.....the BIC F-12 is way better.
I've been PM'ing with Caloyzki quite a bit lately, but I am not much of a help when it comes to subwoofers.
As you all know he currently has a Dayton sub1200. He has 4 options:
1. Least expensive option - Supplement it with an energy XL-S10 for $50 used.
2. Supplement it with another Dayton sub1200.
3. He has an offer to get 2 BIC F-12's for around $300 used.
4. The Klipsch RW-12D for $279.
Which option would you go with?
Is the quality of the F-12's much better than the Energy or Dayton to warrant the extra cost?
I know there's no simple answer to the 1 better sub vs. 2 less expensive subs. I think we've seen that on the last page.
Thanks guys. This is all informative to me as well.
Edited by kgallerie - 4/3/13 at 11:48am
post #37 of 37
Just out of curiosity, are you taking the time to compare posted specifications?
Energy ESW-C10
vs
BIC, F12.
