AVS › AVS Forum › Display Devices › LCD Flat Panel Displays ›  LG 47ls4500 : not happy
post #1 of 4
the 47ls4500 from lg is by far the worse tv ive ever purchased... the motion plus is ridiculous says 120hz looks like 60hz...
and as to updating it. ive tried numerous ways.. none were a success.. I buy TV's for the motion plus.. and I would like to have the option of controlling it.and thanks for the piece of ****.. now I have to drag it all the way back to the store for a refund.. il never buy an lg again..****** techs. need to be replaced.!!!!
post #2 of 4
And you didn't see this before you bought the tv, you just bought it because it said 120hz?
post #3 of 4
Were you not able to adjust the tru motion settings?
post #4 of 4
That is because the panel is only 60hz in that model. There is no settings for this either. LGs line is that is set on at the factory on low and can not be adjusted. Anyone who has seen these models knows it is a lie.
You need to step up to the 6200, 6400 or 6700 to start getting settings for tru-motion although those are still 60hz panels. From the 7200 and above you get a true 120hz panel.
