AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › New House and New Dedicator Theatre Room... Will this work for a projector and screen?
post #1 of 7
So we are moving into a new house in a couple of months and this is the room I have to work with to build the theater. Not ideal but workable I think.
I plan to refinish it with drywall and new flooring but the dimensions will mostly stay as is (though I might loose an inch in floor to ceiling height due to floating floor.
I want to do a projector and given the layout of the doors, etc. I will likely project onto the left wall in the picture, sitting against the right wall. Its almost a square room, and their are no windows in the room (they are in the laundry and study room). Unfortunately there is a large bulkhead covering duct work. I'll put the servers and maybe the components in the workshop (already has built in shelving).
Ideally I'd be projecting against the wall opposite the stairs but the wife is against the idea of our backs towards the stairs (I don't really blame her) so Ive got to make the left wall work.
Whats my best bet? I am mulling something between a 106" to 92" screen. I am not sure a ceiling mount would work give the bulkhead. I'd have to drop it about 2 feet to clear the bulk head.
post #2 of 7
Figure out your seating arrangement and room layout first, then worry about the projector and screen size. The projector can be mounted on the ceiling, it will "clear" the bulkhead as long as the screen is not above the bottom of the bulkhead (easily).
post #3 of 7
The picture will help the smart guys here see what you are dealing with for bulkheads however a floor plan drawing would be helpful as well. Draw it out or use paint with dimensions and you will get helpful suggestions.
post #4 of 7
post #5 of 7
Feng Shui. Its bad Feng Shui to have your back to a doorway. Apparently. ;-)
I don't go for that but in some respects I could see how it could be unnerving if intently watching something, to have someone sneak up behind you unawares as you back is to the main room entrance.
I'll work on a floorplan diagram next (need to take a few more measurements first).
post #6 of 7
door lock
post #7 of 7
I was just explaining to my wife your plight while extolling her virtues as I'm lucky enough to have a wife who absolutely appreciates the design of the theatre around function. My wife requested I post her reccomendations in your thread.
1. Orient the room the way you want it for optimum audio and video (There is no exception to this.).
2. For seating use an L shape sectional couch, if she sits in the corner L she can easily see the stairway to her side with minimal immersion loss.
3. Go 11.2 surround sound so that she is so immersed that she forgets about the stair case.
4. Get a new wife.
Seriously though, the sectional L couch might be a great compromise.
