AVS › AVS Forum › Audio › Receivers, Amps, and Processors › DENON AVR-4520CI Internal Amplifiers
post #1 of 4
I am curious as to the perception of the audio quality of the internal amplifiers from those who now OWN the DENON AVR-4520CI? I will need to design a condo system soon and am undecided between internal vs external amplifiers. There is a need to keep this whole system in the least amount of boxes as possible but also for it to be very high in audio quality though at a relatively low volume level. It will be used equally for Music, Movies and TV (never reference level) and it will be laid out as a 7.0 system with wide front speakers.
For theses, who are using only the INTERNAL AMPLIFIERS, I am also curious as to what you are using for speakers and are you happy with the results?
Chucka
post #2 of 4
The 4520 amplifiers are excellent and deliver very good sonics....
Just my 💰... 👍😉
post #3 of 4
You would be much better served posting in the Denon 4520CI Owner's thread and asking the Owner's directly. You will find a number of them (to include 4311CI Owners) have sold off their external amps as they found the 4311CI/4520CI more then sufficient to power speakers (to include 4-ohm) at reference level volume.
http://www.avsforum.com/t/1430049/the-official-denon-avr-4520ci-thread/0_100
post #4 of 4
Thank you M Code and jdsmoothie. I will re-post this as suggested to the regular Owners tread and see if I get additional replies.
