AVS › AVS Forum › Video Components › Home Theater Computers › 2250 no longer tunes QAM channels
post #1 of 20
My cable co recently just went all QAM. The 2x 2250s (in seperate machines) I have won't tune the channels though -through the WinTV app or through WMC (and I ran a rescan in both). WinTV will pick up the channels - but won't tune them - almost as if they're encrypted. But my TV's physical QAM tuner picks them up just fine. They previously worked - and WinTV indicates the physical channel numbers haven't changed.
post #2 of 20
Who is your CableCo?
Have you verified that the drivers for the Hauppauge! are still current?
post #3 of 20
It's a small hole in the wall company called Advanced Cable in Coral Springs, FL. The Hauppage drivers and WinTV app are the latest.
post #4 of 20
I had the same exact thing happen to me, I was on Time Warner Cable. Never did figure out why it wasn't working. My guess was the QAM tuners went bad.
post #5 of 20
They probably encrypted them all. You will need a cablecard tuner for that.
post #6 of 20
As stated, the TV's physical tuner picks them up and tunes them so they aren't encrypted.
post #7 of 20
Sorry missed that part. Did you try a channel re-scan? Also, did you setup the correct QAM mode (64 vs 256)? Cable providers also shift channel frequencies all the time. It is not the problem for cablecard based tuners because the channel map will tell exactly where each channels are located. Not so for QAM tuners.
post #8 of 20
Yeah did multiple rescans - added what the physical channels are reported as with 256 and 64 modulation and both were a no go.
post #9 of 20
It's my provider ****ing around with the signal - some channels are starting to come back on every new scan - on new physical numbers. Others I still can't tune (whether it reports a new physical number or not).
post #10 of 20
Call them.
post #11 of 20
What is the signal strength on those channels? I assume your WinTV application have something to report that. Ideally, they should be in between -10dbmv to 10 dbmv.
post #12 of 20
QAM 256 +40 SNR/-8 signal strength
Call them.
I have requested a callback - all other attempts lead to being on hold for 2+ hours :/ I see a lot of people bitch about Comcast - I would kill to have them frown.gif
post #13 of 20
They all suck. I don't want to deal with any of them but don't have a choice either which is exactly the reason why they suck.
post #14 of 20
Yeah I know - but at least with Comcast I'm more likely to get others with the same problem to cause a fuss to Comcast - or someone who has come across a solution. Me probably being the only one on my provider in all the HTPC community forums is an even bigger setback to me frown.gif And the city signed a contract with these *******s to be the only provider in town; Comcast offered to buy them out years ago and they refused. UVerse came to the area just a few weeks ago - but no way to integrate that into the HTPC frown.giffrown.gif
post #15 of 20
Just so you know, in some markets, Comcast encrypts all QAM channels.
post #16 of 20
In which case I would just get an InfiniTV - but being that the channels are all working on all my TV's built in QAM tuners - which don't support encryption - it's something else going on with their signal.
Edited by staknhalo - 4/3/13 at 6:47am
post #17 of 20
Yeah in my area all Comcast channels other than the broadcast ones are QAM encrypted.
My ceton and HDhomerun prime work great
Sorry to hear of your troubles.
Curious what is the error you get in WMC when you tune to the channel.
post #18 of 20
Just the regular "There is no signal for the selected channel..." message.
post #19 of 20
Call them.
Maybe a neighbor is illegally taping cable and it is causing signal degradation for you? I am wondering if the signal was better before these issues cropped up?
I would put the phone on speaker phone and carry on about your business while waiting on hold but I think that hold time exceeds that allowed by the FCC. You should complain to the local franchise authority and to the FCC about that.
post #20 of 20
Well I sort of figured this out - while WMC doesn't properly detect QAM channels and requires me to manually add them; WinTV usually scans and picks them all up properly. Some channels would tune in with a new physical number and then would go right back to the old physical number and not tune anymore. Some would never display a new physical number. Out of the ones that would tune - I noticed on the physical channels, all the sub numbers were the same as before; while the primary numbers all now fell between 20-39. So I basically had to create 20 diff numbered channels for each individual channel and see which would tune. It was time consuming, but it worked and I now have all my channels back with the proper physical numbers. Whether WinTV is the problem, not picking up the correct sub numbers - or if it's something in the signal coming from my provider, I don't know. I will contact Hauppage and let them know of all this but after dealing with their support, I don't expect anything to come from it.
