AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Standard SPL Meter for Subwoofer Placement
post #1 of 14
I want to analyze where I've placed my subwoofer. What is a good, known, inexpensive SPL meter. I've read some posts where people recommend Radio Shack meters. Which one is considered the standard? Is it the 33-2055?
post #2 of 14
I have and have used the Radio Shack sound level meter for many years. The Radio Shack meter I have sitting next to me is the model you suggest; Cat. No. 33-2055. The Radio Shack sound level meter is the forum standard.
Recently, I decided I wanted better and purchased several different sound meters to try out and acquired a sound level meter calibration device so as to verify the accuracy of each of the sound meters being auditioned.
This is the current sound level meter being used.
The difference, the one I suggest meets Type 2 standards and can be used for legal purposes (the Radio Shack model is unrated, type 3), reads <60dB (30dB), has a back lit panel and who's measuring microphone column fits standardized calibration devices. So, should one buy a calibration device, they can at home, easily, accurately and regularly, verify the calibration of their sound level meter. This as opposed to wondering or finding need to send the sound meter in for an expensive calibration check.
The device is spec'd to +/-2dB but calibrates out to -0.1dB.
(My only complaint with this unit, the panel back light turns off after five seconds and this timing can't be altered.)
Calibration device used.
Edited by BeeMan458 - 4/3/13 at 7:25am
post #3 of 14
Yes, but a meter by itself doesn't do what you want to. You need software like REW or HolmImpulse to chart in room response. For that purpose this works better:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-808
It doesn't measure SPL, but where charting room response is concerned that doesn't matter.
post #4 of 14
Agreeing with the above, to complete the idea, one needs both, a sound level meter to set the initial volume of their subwoofers and a room analyzing program so the user can physically see the acoustics of their room and how their subwoofers are integrating into the room's acoustics.
If you will, it's all part of a "proper" EQ kit; sound level meter, room analyzing program, measuring microphone and a method to EQ the sound system's output.
Edited by BeeMan458 - 4/3/13 at 9:33am
post #5 of 14
Vs REW?
Measuring gear, programs, three subs. EQ systems.......
(I already have everything else, oh heck, let's throw HolmImpulse into the pot)
post #6 of 14
I can't find this meter on their site
post #7 of 14
Which meter, the Radio Shack meter or another mentioned meter? I'm guessing here, at this point, it may be discontinued.
When I go to Radio Shack's website and put "Digital Sound Meter" into their search engine, this is the sound level meter link that comes up.
Radio Shack doesn't publish the spec's on this unit and the review, in my opinion, wasn't encouraging.
post #8 of 14
I was referring to the 33-2055 that was first mentioned from Radio Shack
post #9 of 14
Give Radio Shack a call and ask them; what's up with that.
post #10 of 14
Originally Posted by BeeMan458 View Post
Vs REW?
I would suggest actually learning to use what you have before adding another product.
post #11 of 14
"Troll"
"...the primary intent of provoking readers into an emotional response[2]..."
post #12 of 14
"Troll"
You calling anyone else a troll - how ironic
My suggestion was serious.
post #13 of 14
For somebody completely new to this topic: what is the benefit of doing this manually vs. using Audyssey from an AVR?
post #14 of 14
If using Audyssey, saving your sanity.
Audyssey has a boatload of incremental sonic filters in which to custom set playback information and does so in a cost efficient fashion. It's not possible to manually equal what Audyssey has to offer with just a sound meter. One would need a sound board (EQ) with enough slides to equal what Audyssey is capable of and then it would frustratingly take hours vs the minutes it takes using the automatic EQ feature Audyssey provides.
The above is not to say Audyssey is a final solution as there does need to be user interaction and there are different levels of Audyssey; XT32 being the most desirable of the three possible choices.
Edited by BeeMan458 - 8/13/13 at 11:08am
