AVS › AVS Forum › HDTV › HDTV Recorders › OTA PVR & WDXLTV?
OTA PVR & WDXLTV?
post #1 of 2
I would like to not have to have my PC running 24/7. I have 2 WDTV Live units with the WDXLTV firmware on them and was wondering if there is a OTA HDPVR that can be plugged right into the WDTV . Then I would use the WDTV box to access the tuner and record and watch my shows... Is this possible?
I have seen where people are using the HD Home run units with the WDTV but I can't figure out if the HD Home run still needs to be hooked up to a PC.
tia,
Ron
post #2 of 2
Yes, the HDHR is just a network tuner module. The WD Live can see it but not use it.
  Back to Forum: HDTV Recorders
