AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Nicks in the edges of discs.
post #1 of 11
I have been combing through my collection and sometimes come across what look like nicks/cracks on the edge of a disc.
This seems to occur more in digipacks.
post #2 of 11
Anyone?
post #3 of 11
It's more likely your player
post #4 of 11
no, they came that way from the factory.
post #5 of 11
I've a few discs, where the outer edge isn't smooth, but can't recall any cracks.
post #6 of 11
RE: Nicks in the edges of discs.
Most of my bd rentals come that way.
Sent from my RM-820_nam_canada_246 using Board Express
post #7 of 11
post #8 of 11
Think it'll lead to rot?
The nicks don't penetrate and are only on the outer edge.
post #9 of 11
Might be a good idea to exchange them or make backups, just in case.
post #10 of 11
The discs are between 2 and 4 years old, my guess is they would have rotted by now.
I think I'm fine.
post #11 of 11
I've decided that the nicks I found on some of my Blu Ray Discs will never lead to rot.
BRDs and DVDs are very different in composition. BRDs are two super thin alloy discs stuck on a plastic disc.
They aren't alloy sandwiched between two plastic discs like DVDs are.
So, a nick on the side of the discs rim will never lead to anything.
  Back to Forum: Blu-ray Software
