AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha 673 v. 671
Yamaha 673 v. 671
post #1 of 3
So right now I can use to points on my credit card and save $100 on amazon. My question is they have a "like new" 671 for $239 so I would pay 139+ tax, or is it worth the extra money for the 673 which is currently on sale for $379, which I can get for $279 after I use my points. I know the 673 has airplay and 4k passthrough.
Which do you recommend?
post #2 of 3
If you don't need Airplay or the 4K passthru then get the 671. The two units wont sound any different.
post #3 of 3
I dont think i need the 4k pass thru now, I dont intend to buy a new TV in the next 5 years. I am wondering how much I would use the Airplay. I do have an iphone and ipad, are the main benefits that I can just stream wirelessly, otherwise I just plug my device into the usb on the receiver?
