AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › configuration of lg 60pm9700
post #1 of 3
Can someone give some specifications of how much contrast,color, brightness....... for excellent image.
Recently bought a lg 60 pm9700 screen, it looks great but i think it could be better.
Thanks for all
post #2 of 3
Thanks for all
Edited by JSpectre88 - 4/4/13 at 6:41pm
post #3 of 3
I've had mine for 4 weeks and have been running it on the THX cinema mode and watching full screen programming (w/o logos) for break-in. I'm almost at 100 hours and will most likely use custom settings after I log more hours. I found out that the THX mode puts the aspect ratio to "just scan" and on my uverse that leaves a small band on some of the movie channels, so I've been changing that to "16/9" after I turn the set on. I run the "colorwash" program every few days as well.
