AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Home theater seating riser tread lighting
Home theater seating riser tread lighting - Page 2
post #31 of 41
Oh gotcha. Yep just used standard non waterproof strips connected with 4 wire
post #32 of 41
Got it, I have tons of the 5050 with waterproof covering. You think that will fit in the track or will I need to take the waterproof covering off.
post #33 of 41
your LEDs would not probally fit in the track i used. It is designed for 3528s and is a rather tight fit laterally. But im sure there are other tracks that will fit both 5050 and water proof LEDs in them
post #34 of 41
How did you cut the lens?
post #35 of 41
just used a chop saw then used a steel file to get the burs off.
post #36 of 41
Chop saw as in a miter saw for wood, or a chop saw for metal?
post #37 of 41
Miter saw for wood. But I also used a cutting wheel on a radial arm saw that worked real well too.
post #38 of 41
If you guys have any additional photos, ideas to share I would be appreciative as I’ll be working on my 2nd row riser here in the next couple of weeks. Thanks, David
post #39 of 41
Use electroluminescent wire. Cheap and awesome
http://www.lighttape.com/library/LumaGrip%20at%20Boujis2.jpg
post #40 of 41
I liked those too. Only issue is it didn't fit into the design of the room. The plastics took away from the very sleek modern classy design. They just looked like an after thought.
post #41 of 41
