AVS › AVS Forum › Audio › DIY Speakers and Subs › Dual Rythmik FV15Hp`s/upgrade to diy?
Dual Rythmik FV15Hp`s/upgrade to diy? - Page 6
post #151 of 403
Ok, I`ve got them all hooked up and the they all work:) but I had to turn the gain up all the way to hear much out of moderate volume music, guess I`ve got a lot of playing to do and of course haven`t done Audyssey or sms yet, just plug in and play.
post #152 of 403
You'll need to adjust the levels. Are you using xlr from the SMS to the amp?
post #153 of 403
Not using the SMS yet, xlr from avr to amp.
post #154 of 403
ahhh yes. youll probably need more signal going to the amp than the avr puts out. the sms can possibly make up for that. if not, you can use one of these:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=245-868
are you using one cable or two?
post #155 of 403
What do you mean, one or two? I have two of those already.
post #156 of 403
Are you using one output from the avr or two?
If one. Make sure the amp is set to parallel
post #157 of 403
Subwoofer1 and subwoofer2, amp is set to parallel. I've got two clean boxes already, how do I hook them up? Between the avr and amp?
post #158 of 403
If your using two different inputs on the amp. Change it to stereo. Yes the clean boxes go between the avr and the amp. They will allow you to increase the gain going to the amp. Might as well just run rca to the clean box then xlr to the amps.
post #159 of 403
Ok, I thought parallel had to do with the speaker set up.
post #160 of 403
Nope. It sends the same signal to both channels. Used when your using one input and both outputs. Kind of like Mono. The stereo setting is for two separate input and output signals like your doing.
post #161 of 403
Oh ok, I've got some extra XLR cables so I'm going to use those instead of RCA , should I use one cleanbox or both?
post #162 of 403
Oh, I am getting a signal to all four subs, just weak!
post #163 of 403
Just one clean box is necessary.
post #164 of 403
Ok.
post #165 of 403
Hooked up clean box, switched to stereo, nothing, now I`m getting discouraged!
post #166 of 403
I think you need to use rca into the clean box. Then xlr out. It looks like it converts whatever you put in.
post #167 of 403
Yes, that makes sense. I have a butt load of cables but don't have any short ones, guess I`ll be going RS or Best Buy or somewhere tomorrow.
post #168 of 403
Try whatever rca you have first. Just to make sure.
post #169 of 403
I will!
post #170 of 403
Ok, the cleanbox did the trick but there is sort of an issue, the output 1 knob on the CB has no affect on the volume level at all, but the #2 knob turns all 4 subs up or down, I tried both boxes, what`s up with this?
post #171 of 403
Also, I want clean these cables up, will there be a signal issues if I put the cables from two of the subs in the same raceway since there not shielded?
post #172 of 403
No. They will not interfere with each other.
As for the gain issue on the clean box, I'm not sure. they are supposed to work indapendantly. The amp is in stereo mode correct?
post #173 of 403
Yep, stereo. Definitely something weird going on, even running Audyssey the gain knob on 1 doesn't do anything and the #2 will turn the volume up or down.
post #174 of 403
Another question. Right now I have the amp plugged in the wall but have room on my power conditioner for it. My Emotiva amps are plugged in the walls because Emo says that fine to do, what about this amp? Also kinda sucks this thing doesn't have a trigger, have to turn it on and off manually, is replacing these fans with more quiet ones very difficult?
post #175 of 403
Tried changing cables around and still the same, only channel 2 output knob has any affect, on another note though, I ran XT32 and the initial results are pretty good, played some music and the first ten minutes of Transformers and had the explosions at 105db at +12.5 on my 5508 and it was very nice. I think once I run Pro/SMS and do some more experimenting this will be awesome!
post #176 of 403
Post a picture of the amp rear panel, so we can get a visual of what exactly you have going on back there...
post #177 of 403
help at all? I have more!
post #178 of 403
i use the wall version of this to trigger my amps. http://www.adorama.com/FUMP20.html?gclid=CPHXquLZ8LYCFQVV4Aoda1IAEw
post #179 of 403
Yes. Show us how you have your output wired as well.
Link error. Please fix.
post #180 of 403
Kind of expensive for one trigger, know of anything else?
