AVS › AVS Forum › Audio › DIY Speakers and Subs › Dual Rythmik FV15Hp`s/upgrade to diy?
Dual Rythmik FV15Hp`s/upgrade to diy? - Page 7
post #181 of 403
Yes. Show us how you have your output wired as well.
Link error. Please fix.
works for me
post #182 of 403
Originally Posted by mal01 View Post
Kind of expensive for one trigger, know of anything else?
not that can handle a 20 amp circuit.
there are home brewed ones for cheap, but i didnt want to mess wtth them.
post #183 of 403
post #184 of 403
post #185 of 403
in that first pic. it looks like you have them plugged into the speakon connection. are they speakon ends or xlr?
post #186 of 403
Your right Brian, I have committed an noobie error, I know I tried to insert them there but they wouldn't fit so I thought well, I`ll just stick them in here:eek: I`m sure it make a difference, maybe I don't even need the CB. I`m doing some cable management right now and have them off, I`ll rewire and try again.
post #187 of 403
folks have done the same thing with much worse results........... tongue.gif
post #188 of 403
post #189 of 403
Gone back and tried to hook up again and see what happened, xlr female to 5508, the xlr connection on the amp is male, so I have two male ends, do i have the wrong xlr?
post #190 of 403
Oh, i'm not on a 20amp.
post #191 of 403
Yep
post #192 of 403
You can go rca to the SMS and xlr from the SMS to the amp with that male to male cable
post #193 of 403
Color me confused... How were you able to get a signal at all to the amp?
One thing at a time.
post #194 of 403
Brian, I'm not using the SMS at this time, what other kind of XLR is there?
Austin, RCA out from avr to input of CB, Used XLR from CB output to the Input of the amp connections that aren't XLR, whatever the he'll they are called(link)?
post #195 of 403
I was just saying the cable you have now would work with the SMS. You need a male/female cable to hook it up the way you have it. Monoprice.com will have them.
post #196 of 403
My XLR is male/female. I got them from mono price .
post #197 of 403
post #198 of 403
post #199 of 403
post #200 of 403
Ok. Looks like you need female/female
post #201 of 403
Where do get that?
post #202 of 403
Looks like have to get a f/f coupler.
post #203 of 403
No... Upon further investigation please reference page 8 § 2. of your owners manual here:
CV5000 Owners Manual
The CV5000 takes a Male XLR input connection.
post #204 of 403
That's where I had them, but was having the issue with the CB.
post #205 of 403
that sure looks like it takes a female connection to me Pop
post #206 of 403
Mal, any updates??
post #207 of 403
Originally Posted by walke108 View Post
Mal, any updates??
Not as much as we would like to.
We love to go up to Traverse City. My sister in law and her husband also have a place in Gaylord.
post #208 of 403
Originally Posted by brian6751 View Post
that sure looks like it takes a female connection to me Pop.
The XLR input on the CV5000 "is" female and it "takes" a male connector, which he currently has. No need for a female-to-female adapter like he was anticipating. I gave mal a call yesterday to clear it up.
post #209 of 403
Everything is up and running fine, it was hooked up properly, but I am using two Cleanboxes right now but still have a weird issue with the gain knob, it doesn't appear to be affecting performance. I am going to get the subs as close to equal distance from the MLP as possible and run Audyssey Pro and start trying to hook the SMS back up, its been awhile since I`ve used it. I have a question about co-locating, what`s the difference in co-locating in order to get more output and just turning up the amp some if I have plenty of headroom left?
post #210 of 403
Colocating generally gets you 3db of free output. No increase in power needed. If you have headroom to spare, it's best to spread them out.
