AVS › AVS Forum › Video Components › Home Theater Computers › Stuck at unsupported resolution.
post #1 of 5
My pc is currently locked at a resolution on startup that my crt doesn't support. All i see on startup is squiqly blue lines. Is there a reset button somewhere? Do i need to plug in 2 displays simultaneously to fix it?
Edited by Mik James - 4/5/13 at 9:08am
post #2 of 5
If you are running windows are you able to use F8 and get into safe mode? (I am trying to rule out a bad monitor)
Also if you enter the BIOS screen do you still have the issue?
Edited by Josea - 4/5/13 at 9:36am
post #3 of 5
All startup screens/white text is solid up until windows loads. It started when i selected 1366x768 by right clicking the control center icon and I guess it didn't load my custom 1366x768 scaled to 1080i like it does through the catalyst desktop resolutions area.
I connected an lcd and set it to 1080i as well but i believe amd uses seperate monitor profiles so it didn't help.
post #4 of 5
Have U tried F8 after power on - enable low resolution video ... - then once in windows setting a non-custom resoution?
post #5 of 5
Sounds like a plan. Thanks
Worked as advertised, thanks.
Edited by Mik James - 4/5/13 at 12:30pm
