AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › Help for new GPU
Help for new GPU
post #1 of 3
Hi I really need help finding a budget graphics card. My budget is about $200 but less would be great. My current specs are:
Gt 610
AMD fx 41000 3.4 Ghz
8 Gb RAM memory
500 Watt Power Supply
1 terabyte hardrive
Forgot my motherboard sorry it's a gigabyte though
20-22 inch HP monitor
I need to replace my RAM sticks as they are corrupted which I why I'm on a this type of budget any help would e awesome! Thank you in advance
post #2 of 3
Geforce GTX 650 Ti Boost 2GB. Be very specific that you are getting the Boost version. It is very much a GTX660 Lite, which is a rad card. The 650 Ti is more of a fast 650, which is a lot more cut down. The brand doesn't really matter, just get one with two fans so that it is quieter. The single fan designs are still noisier under load.
The Ti Boost is like $180 at Newegg of I recall? Very compelling offering.
post #3 of 3
Paid $169 for mine. Incredible card for the money. The zotac one I have is super quiet too.
  Back to Forum: HTPC Gaming
