AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › more than 2 sub on 7.2 avr ...
post #1 of 3
how can i connect more than 2 sub on my rxa1010 since it only have 2 sub out ? can i just buy a splitter and use it on one of the output !??
ive been told before it would lower the sound of the 2 subs that are connected behind that splitter ...( since the signal is splitted in half )
post #2 of 3
This is the splitter that I'm currently using and once gain matched, any signal strength loss is ameliorated.
Ten bucks delivered and top of the line build quality.
post #3 of 3
Use a Y connector. The voltage to the inputs of both subs will be the same as they're parallel loads. There is no signal loss.
