AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Finshing my basement. Need advice on a box to to distribute my DTV HD signal
post #1 of 3
I currently have DTV HD (1 cable in to a multiplexer out 3 receivers) This multiplexer is just installed up in my floor joist. It want to move it to some sort of in wall box (like a breaker box) to have more options in the future and easy to get to as I am refinishing my basement and this will be covered with drywall soon. Any suggestions on this?
post #2 of 3
You need to decide on the size, depending on what else you want in there.
Search cocoontech forums for 'enclosure' for tips and tricks.
I've been happy with Channel Vision enclosures.
post #3 of 3
  Back to Forum: Home A/V Distribution
