AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Hot Amp
Hot Amp
post #1 of 7
I have my Blu Ray, two direct TV boxes on top of my Onkyo amp. There is some clearance, but I feel it's not enough.
These components are in a clost that is roughly 8 feet high by 4 feet wide.
There is a shelf the amp sits on and everything else sits on top of that.
Are there any stackable type racks, wires shelves or anything I could possibly purchase so I can gain more clearance above the amp.
I currently have a fan attempting to blow the air out, I keep the closet door open.
Also, looking for a good cooling fan, pad or whatever to place on top of amp.
However, I'm more concerned about creating space between my amp and blu ray and direct tv boxes.
post #2 of 7
You should NEVER have anything on an amp/receiver.
post #3 of 7
There are many different types of shelving and racks for mounting home entertainment equipment. People with many devices (amps, processors, players, etc) often use industrial 19-inch "relay racks". Some examples are shown in http://www.avsforum.com/t/788074/show-me-your-rack/1530
You might consider visiting a local audio-video store to see what's available.
Check your receiver's manual, but usually 6-8" inches of clearance is required on all sides. If you can't provide that much, a fan will be required.
post #4 of 7
How about if I just build one level if shelving out of mdf and raising it the required clearance per the owners manual
post #5 of 7
I didn't even think about this, but I could put the blu ray on the bottom, build a stable rack and then have the amps it on top, would have almost unlimited heigth above the amp.
post #6 of 7
That sounds like it should work very well!
post #7 of 7
I've used wood strips - something like 2 x 2 lumber for that purpose. I have a table saw and just cut stock to suit.
In the end you should restack your components with the hot one on top.
