AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 4310CI - OPPO 83 - SACD help
post #1 of 12
When I used to play SACD's in the oppo, the display on the denon would show SACD
Now it shows multi in
What changed in my settings?
Connection is via hdmi
post #2 of 12
The AVR should display either "DSD Direct" or "DSD Multi Direct" if the Oppo is bitstreaming the audio to the AVR to decode, or it will display "Mult CH IN" when the Oppo is decoding it. A setting likely got changed in the Oppo. smile.gif
post #3 of 12
I remember the denon displaying SACD in the past
post #4 of 12
post #5 of 12
Thanks but
I am not that much of an idiot
post #6 of 12
You just remember it wrong. It's all clearly set out in the Manual p.72.
post #7 of 12
Yep. Maybe he's remembering it saying DSD DIRECT?
post #8 of 12
It's possible I am remembering it wrong, it's been some time since I listened to an SACD
I was sure that SACD came up and not multi
post #9 of 12
I have the 4311 and have played many SACDs with it. I've never seen "SACD" displayed on the 4311's display. I see DSD Direct or DSD Multi Direct if my 103 is set to DSD. If my 103 is set to PCM then I see Stereo/Direct or MultiCH on the 4311's display. I would say your memory is playing tricks on you wink.gif.
Bill
post #10 of 12
Thanks Bill!
What is the preferred out put on the oppo - DSD?
post #11 of 12
Originally Posted by wlcohen View Post
Thanks Bill!
To be honest I bounce back and forth between DSD and PCM. I was convinced that I could not hear a difference between DSD and PCM but at times I use the DSD setting. I only use DSD for stereo SACDs as no bass management is needed. When listening to multichannel SACDs I use PCM then the 4311 does bass management and Audyssey as well. So I would suggest trying both the DSD and PCM settings to see which you prefer.
Bill
post #12 of 12
Is the Denon 4310 even capable of direct DSD to analogue decoding?
If yes, you forego BM and EQ as Bill said and you'd need all 'large' speakers. OK for 2.0.
If no, then does it downsample PCM?
Does it do BM correctly?
