AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Recommendations of 60+ passive 3d TV for under 1500?
post #1 of 4
Looking for recommendation of 60 or 65 inch TV that has 1080P and 3d Passive. Looking to replace my 5 year old 50 inch Plasma Panny. Since i have an Xbox and PS3 don't really care about the smart apps etc but always a bonus.
What is the best time to buy tvs for discount ? Please make any recommendations, I was eying the following model, appears to get very good reviews: 65” VIZIO Razor LED 1080p 240Hz Smart HDTV w/ Theater 3D Model: M3D651SV
post #2 of 4
I was also going to suggest Vizio but hold off for now because the M series (like the one you referenced) is getting a massive overhaul this year.
That screen was so highly praised that they're extending the line from all sizes from 32" to 80" and giving it a very nice makeover.
There isn't much information right now but search around for "vizio m series 2013" and you'll find what's out there. I'm personally waiting for the 70". Release is rumored to be in May.
post #3 of 4
I just took a stroll through Sams at lunch and noticed a bunch of Vizio M series. Maybe they are 2012 model but they all looked very nice in terms of bezel and appearance
Maybe you are right because only walmart carries the 65 inch at a decent price. Amazon doesn't have it, Sams is out of stock.
post #4 of 4
http://www.youtube.com/watch?v=x9lfghU69I0
Video says first quarter this year so yep might be soon enough
