AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk]
Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 157
post #4681 of 13986
Originally Posted by vinnie97 View Post
Ps. Sally, did you mean warm2 color temp? There are only selections for cool and warm IIRC.
The bezel literally merged with the black bars on Place Beyond The Pines tonight.
Looking forward to watching that, haven't had time yet.
post #4682 of 13986
I enjoyed it minus the length, pacing and (somewhat) predictable second-half. smile.gif
post #4683 of 13986
Will the VT's (or ZT's) HDMI inputs be upgradeable to HDMI 2.0?
post #4684 of 13986
Nope.
post #4685 of 13986
Not very likely but have to ask the question.
I thought HDMI 2.0 had to do with 4K . This display is 1080P and wouldn't benefit with a higher resolution input. So why would you be interested in HDMI 2.0 for this particular display?
post #4686 of 13986
Does anyone know what audio formats the TV can decode input into its HDMI inputs?
I've tried Dolby Digital 5.1 by setting my Sky box to output "Dolby D" over HDMI but the TV is silent.
I've tried similar on my PS3 but same thing.
Does anyone know if the TV can downmix any of the surround sound formats when they come in via HDMI?
post #4687 of 13986
Higher frame rates and an enhanced color space (though the next question is where will one find the content other than with camcorder recordings or the like)?
post #4688 of 13986
How exactly are you connecting everything? And what is your source material? Are you attempting to use ARC with a receiver?
If you connect the PS3 directly to the tv via HDMI you will get 2.0 sound from the tv speakers.
Edited by Bond 007 - 9/6/13 at 6:51am
post #4689 of 13986
Yest Normal, and yes in-between Color Temp Warm 1/2 and Cool 1/2 you will find Normal.
ss
post #4690 of 13986
Has anyone here noticed any green blobs that a few VT50 owners including myself have experienced? Panasonic was great in replacing my VT50 for a new VT60 due to these blobs. So far I have fantastic uniformity and no blobs associated with the VT60, but I was just curious if anyone had heard or experienced anything different. Thanks.
post #4691 of 13986
Connecting the source to the TV via HDMI.
In the case of the Sky box, you can set it to output Dolby Digital 5.1 for certain things like Sky Movies. The TV plays no sound when the Sky box is emitting 5.1, although when it emits stereo it's fine.
In the case of the PS3, I set the audio output to HDMI and set it to output Dolby Digital 5.1. TV is silent.
In all cases its ok if the source outputs stereo.
The thing I'm not sure about is whether its just my TV that is maybe faulty, or whether this model, in general, can't decode and downmix surround sources to stereo in order to output via the TV speakers.
No ARC. Just expecting the TV to output stereo through its speakers even if supplied a surround input.
post #4692 of 13986
Nothing like that so far, but realistically it's going to take more time as no one's VT60 is going to have a ton of hours on it yet. I'm hoping that yellow blob issue is solved. I did end up getting the Geek Squad warranty just in case.
post #4693 of 13986
That is strange. I dont have that model so I cant test. But it would seem that it should take any signal from the PS3 and downconvert it to stereo.
post #4694 of 13986
That's what I would have thought as well. Its the TXP65VT65B that I have. Wondering if anyone else on the forum that has the same model could test it out for me please?
post #4695 of 13986
That's what I was about to say. It's just not been long enough to draw any conclusions.
You might want to go to the yellow blob thread and try to figure out how long it was before they started showing up.
With that said, I would STRONGLY recommend getting the extended warranty.
Edited by JimP - 9/7/13 at 11:21am
post #4696 of 13986
I bought the extended warranty on my previous plasma and never had a need to use it.
Because of that, I didn't bother getting it for the Panny VT50. Now I'm starting to see some off color in some areas of the screen during some unique situations. Not all the time.. Doing the VSUS adjustment eliminated it .
I bought my ST30 late in 2011 and didn't bother with the extended warranty because I was aware of the known potential issues of that set and they were minor to me. But, hearing some of the yellow blob stories, I didn't want to take a chance on the VT60.
post #4697 of 13986
I'm new to the forum, and thought someone here might have some suggestions to fix a problem I'm experiencing. I recently purchased a Panasonic TC-P65VT60. It's connected to a Yamaha RX-A1000 via a high speed HDMI cable using the ARC HDMI port 2 on the TV. I have changed the settings on the TV and the receiver to activate ARC. I use a Harmony 900 and I have an HD DVR connected to the receiver as well. All my components are connected to the receiver, and the receiver is connected to the TV. On the Harmony, I have the components to watch TV turn on in the order of, from first to last, the TV, the cable box and the receiver. However, when I press the watch TV button on the remote, while all the components turn on OK, the sound comes out of the TV speakers instead of the stereo speakers. I discovered by accident that I could get the sound to come out of the stereo speakers by turning the receiver off and then back on after all the components were already turned on. The only way that I figured out to get the sound to come out of the stereo speakers when first turning on all the components together was to have Logitech program a 5-second delay into turning on the receiver. This is a bit annoying, though, and I wondered if someone might know a better way to make the sound come out of the stereo speakers when turning on the TV, cable box and receiver at the same time. I have talked to Panasonic tech support several times, and there's nobody there who knows how to fix the problem. I was promised that a higher tier tech support person would call me, but that never happened. Thanks.
post #4698 of 13986
You have the problem fixed with the only solution I am aware of. Enjoy.
post #4699 of 13986
Have any of you noticed that the right side of the panel, or left if you are looking at it from behind, is quite hot to the touch.
Do you think this bodes poorly for longevity?
post #4700 of 13986
I dealt with the same issue. If you're going to use ARC, there has to be a power on delay between the TV and the Receiver. The only way to get this functionality with the Harmony remote is for their services to add this ability to your Logitech Harmony account. I was told that it would cost (don't know how much) since my remote was out of warranty (90 days). I decided to just use the optical digital out from the TV to the receiver. I don't know the real advantages of ARC over optical digital out other than it saving a cable, but the optical digital out works perfectly.
post #4701 of 13986
A lot of people have noticed that. It seems to be normal in the sense that all this year's VT60s run hot like that. The case gets very warm and I would presume the components radiating the heat are warmer still given that there is an air gap between the components and the case (air is not a good conductor of heat).
I wouldn't like to guess what it means in terms of longevity. Perhaps, e.g., an electronics engineer could make some relatively informed statement on that?
I do know that many products in the past have failed early with that failure being attributed to poor thermal management. For example, some Apple time capsules had an unexpectedly short lifespan with many failures after about 18 months of use. There is more information about it here. In that case the problem was thought to be the proximity of a hot power supply to electrolytic capacitors in conjunction with poor cooling. Well, the VT65 also has electrolytic capacitors positioned vertically above what is apparently a hot part of the TV. It would be a step too far to conclude that the VT65s will start failing after about 18 months of use. But still, I would feel more reassured if these things ran cooler.
post #4702 of 13986
Hello everybody, I have owned a 55VT60 for the last 48 hours and still getting used to it. I am having an issue outputting sound from the Netflix app on the TV onto my Denon AVR-1713 which supports ARC. I was wondering if anybody else had the same issue? I am using HDMI2 on the TV and the only pertinent setting I find on the Denon is under HDMI Audio Out, it can be set to TV or AVR. Tried both settings, sound still mute playing off VT60's Netflix app. Thanks!
post #4703 of 13986
ok, so adding oblivion to my blu -ray collection....vt60 did good looks amazeing. and sound omg neighbors are hateing me lol smile.gifsmile.gif
post #4704 of 13986
For the prices they are at, its kind of a no brainer. Especialy on units $1500 and less, because if they fail they are throw away TV's, not worth fixing.
post #4705 of 13986
Well I am very happy. I upgraded my 65vt30 to a 65vt60 after procrastinating, I said screw it and just did it. Whatever you only love once.
post #4706 of 13986
Congrats, Semp! You will really enjoy the increased picture quality over the 30!
post #4707 of 13986
When I drive the display at 59.94 from ye olde htpc it looses sync and the screen goes black and then comes back periodically. 60hz does not do this. My old commercial panny plasma did not have this issue with this htpc rig.
Bummer. Great display otherwise.
post #4708 of 13986
I know there is another thread for this, but have any of you had the "foam fix" done for the fan noise after purchase? If so, is there improvement?
Also, can any of you relate how much brighter the ST60 is vs. the VT60? I came from an LCD so I've naturally been used to a brighter picture, but the VT60 appears pretty dim with not a lot of light in the room unless I have the panel brightness set to high, ABL is off. I'd hate to lose the picture quality, but I've considered going to the ST60 for the fan noise alone. As stated above, the back panel on the right side (facing the TV) gets very hot. Not sure if this is related to the fan noise or not.
post #4709 of 13986
High panel brightness does not produce an accurate picture and abl can't be disabled , maybe you mean the Eco setting that find the picture based on room light ?
The st60 might be a better choice for you if your room is very bright
post #4710 of 13986
Hi, I recently purchased a TCP60VT60, and I just want to make a simple connection from my laptop to the TV. I tried connecting the HDMI cable from my laptop to an Onkyo receiver (HT-R990) and the tv display won't adjust properly on 1080p (2d) mode, the computer screen doesn't fit properly on the TV. Although, when trying the 1080p (3d) mode, it does fit on the screen but I see little dots and if I playback a 720p video for example it has a huge delay, and everything else, like navigating through the windows menu and stuff. I tried adjusting the screen size to a lower resolution but with the receiver none of them are good. When I connected the HDMI from laptop directly to TV, I found a screen resolution that was ok, which was 1360x768. Question is, how do I setup the HDMI settings on Receiver and TV to 1080p and with no delays?
