AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Purity Power Base - Need Assistance
post #1 of 3
Wondering if anyone is familiar with this unit. I have had one for about 8 years and it has performed flawlessly. Just moved it to a new house, and am having some problems, specifically a "hum" from the unit when I don't ever remember there being one. I am hoping someone can answer a few questions...
What color is the front light when on?
Does anyone have a copy of the manual?
Has anyone ever heard a "buzzing" from the unit?
Looking for help.
BTW: the front light seems to flicker purple.
Peter
post #2 of 3
1. Light is orange/red when viewed straight on (it's recessed and if viewed from an angle looks almost yellow but at eye level it's an orange/red
2. I'm pretty sure I have it but would need to locate it.
3. It has a faint buzz when your ear is right next to the unit but not outright loud
post #3 of 3
Let me clarify -
From a distance the light is a pale blue but if you look directly at it from a few inches away, behind the "lens" is an orange/red "element." I know it sounds crazy - difficult for me to explain.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
