AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Question regarding an isolation clip, double dry walled room and outlets/switches
post #1 of 5
So I'm planning a small dedicated media room, and am going to be doing isolation clips, double dry wall, and green glue. The question that keeps coming up, and one that I don't have a solid answer for yet, is what does the builder do with all the outlets, switches, and wall plates that are planned in the room?
Am I going to need to build a backbox for each of these, and then they mount inside of that backbox?
What if they need a stud to tie to?
What if the wall plate is only a mud ring, and no electrical box?
If they use retro style electrical boxes, will that pass inspection on a new construction home?
How have your outlets/switches been done in your theater/media room?
Thanks guys
post #2 of 5
It is actually possible to build a theater with no wall pentrations for the outlets and switches. You have to put them in columns, riser, stage and surface mounted behind a screen wall.
Put that is not always possible so PUTTY PADS
post #3 of 5
I think one of the answers the OP may looking for is the use of adjustable boxes to account for the extra layer of drywall.
post #4 of 5
well I answered that last night in another thread
post #5 of 5
