AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › F8500 Recommended Settings Thread.....
F8500 Recommended Settings Thread..... - Page 13
post #361 of 2077
Originally Posted by pieandchips View Post
First calibrate the Movie mode. Input those numbers into CAL-DAY & Night. If there are issues they'll show themselves.
Originally Posted by Syllogistic View Post
Can I ask, for those who've calibrated the F8500, what type of pattern are you using?
The calibrators at the Shootout recommended Windows APL patterns for the F8500. They didn't say why.
post #362 of 2077
Less ABL?
I used Windows APL.
post #363 of 2077
Less ABL?
I used Windows APL.
Yes, less ABL, but they liked APL patterns for the F8500 and 10-18% Windows on Black for the V & ZT.
post #364 of 2077
^ Interesting, as the bigger the window is I would expect more ABL kicking in. Perhaps the size/light intensity is just below where ABL activity begins on these sets.
One thing I did notice was whenever the menu system is displayed (i.e. always when adjusting things), the meter picks that up (must be the diffused light bouncing around inside the filters) and the readings changed slightly.
Therefore I made all the readings with menu/slider up as opposed to half and half so as to balance the readings with the same spurious data.
-Correct way to go?
post #365 of 2077
If the menu is affecting the readings, do a run with the menu off, make the approximate adjustments, turn the menu off, do another run. Iterate until you are satisfied.
post #366 of 2077
Yeah maybe sometime soon. It would increase the calibration time by a heck of a lot, especially having to drill down into the over spanned menu areas. I recall a comment from D-Nice saying the menu sliders affected readings slightly.
I wish this TV had Autocal and/or a method of altering the settings via IP.
That would be nice. Hopefully by the time the K9000 OLED comes out tongue.gif
post #367 of 2077
Pieandchips
Two questions:
1. Black optimizer is off and greyed out, how do I change this
2. Same issue for white balance (10 pts)
Any suggestions?
post #368 of 2077
^ What is your source?
post #369 of 2077
Blu-ray
post #370 of 2077
Change your Picture mode to Movie. I think you may be in another mode.
You should get all options playing a blu ray.
post #371 of 2077
Is there any limitation that you should not go beyond when tweaking your TV's picture to avoid damaging your TV,and which sub-menu exactly that you have to practice more caution when adjusting?
thanks
post #372 of 2077
thanks
Not sure what you are refering to as you should be able to adjust any of the standard modes (normal menu) without "damaging" your TV. If you go into the service menu however, you can cause some real damage and unless you know exactly what you are doing stay out as any changes made there will not be covered by warranty)......
post #373 of 2077
thanks,I'll be more specific,e.g. here it say's
Code:
Cell Light -16 (Adjust level to taste - cell 16 = 45fL/Average Bright)
to your taste,does that mean I can go all the way down,let's say to 3-4?
http://www.avsforum.com/t/1467675/f8500-recommended-settings-thread/150#post_23308141
post #374 of 2077
Code:
post #375 of 2077
Code:
you could if you want, but at 3-4 the set would almost be off wink.gif Remember the settings are just a starting point, adjust to your tastes so that you'll be happy with the picture smile.gif
post #376 of 2077
I see at the shootout that the gamma seems to have been set to 2.4. I also see people on here calibrating to a higher gamma also, why is this? I thought 2.22 was the standard? Do you have to calibrate to a higher gamma if you're going with a higher ftl? I'm getting the 60" soon and I'm just wondering what gamma I should get mine calibrated to, I like about 50 ftl. I'm guessing Cell 18 would be about 50 ftl?
Edited by Slickman - 5/20/13 at 9:25am
post #377 of 2077
-Correct way to go?
It takes much longer to do it with the menu off then , making a change and then take the menu off again , and so on. I just changed and did it with the menu off and then measured a full run with menu off and then adjusted again with the menu on and finally a run with menu off. The changes are very minor with the menu on but yes it does affect the readings though minor.
post #378 of 2077
thanks
I wouldn't enter the service menu, this is where you could possibly brick your tv. There is no limitation in the user menu the only thing is if you don't' have a meter I would just use a free disk or a set up disk and do a basic picture set up. Copying someone elses calibrated settings don't appy to your tv set. Basic picture control set up includes , Contrast, Brightness, Color/Tint, Sharpness and turning off any enhancements. Do not adjust white balance without a meter.
post #379 of 2077
Originally Posted by Slickman View Post
I see at the shootout that the gamma seems to have been set to 2.24. I also see people on here calibrating to a higher gamma also, why is this? I thought 2.22 was the standard? Do you have to calibrate to a higher gamma if you're going with a higher ftl? I'm getting the 60" soon and I'm just wondering what gamma I should get mine calibrated to, I like about 50 ftl. I'm guessing Cell 18 would be about 50 ftl?
Higher gamma is usually dependent on the light in the enviroment, a dark room is a higher gamma ex: 2.4. The shoot out calibrated it to 2.4 in a dark room setting i don't think it was 2.24. Not all movies are calibrated to 2.22 , actually there is really no standard in the sense that one studio doing the mastering has it set to a specific value it's kind of all over the place. But a good aim is for 2.25, some calibrators say between 2.22 and 2.35.
post #380 of 2077
I think this was vaguely discussed previously, but has anyone done measurements between the cell light and contrast to determine the best combination to minimize ABL? I know the F8500 has less noticeable ABL in general, but just trying to get some kind of indication as far as interaction (to optimize) and such particularly below 40fl. I was going to ask Chad to explore this on my set when he eventually comes out, but in the meantime just looking for an indication.
post #381 of 2077
thanks hungro,Neither do I
all I'm asking is about picture menu/sub-menu?
post #382 of 2077
Anybody else has problems with setting calibration values in their F8500 due to slow menu? About every time I try to play with the calibration menu it practically crashes after a while (takes minute or two to respond to remote) and is making it impossible to dive e.g. color settings where you have to set several different values in the submenu. Rebooting the TV does not seem to help.
post #383 of 2077
^Yes I had that before a couple of times. The fix was to pull the plug for 10 seconds and make the TV do a cold boot.
The menu should return to normal fluid operation after that.
post #384 of 2077
Updated calibration to revision 3.1
Very slight tweaks to colorspace and 10p control.
Added a calibration report.
Edited by pieandchips - 5/23/13 at 3:49pm
post #385 of 2077
thanks,I thought this thread died,will try it later.
post #386 of 2077
Hey pie where is your new calibration? Would like to try it on my set
post #387 of 2077
check the link in his sig.
post #388 of 2077
Thank u Airgas
post #389 of 2077
Pie
THANK YOU, THANK YOU, THANK YOU.
Your calibration is so good to my set. Very happy with the result.
The blacks are inkier now, love the colors too
Great job my friend
post #390 of 2077
Good good glad it's helping.
