AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Multizone with Airport Express
post #1 of 3
I'm looking for the best way to set up 4 separate rooms (2 passive in ceiling speakers each) that I can separately control with my iphone/ipad. Sonos is great but expensive. My idea was to have 4 separate airport expresses (one per room which is how I would control each room independently) and pair with a multizone amp. Would that work? The airport expresses would always be in powered up so, if I selected one to play music in a room, would that turn on the amp or is that always on too? Would I be able to control volume from my iphone? If the airport express idea wouldn't work, would a sonos solution solve the problem? Sorry if this is naive, but I don't know much about these kind of setups.
post #2 of 3
Four APE's would work, but why send wires back to a single multizone amp? Whether they turn on the zones or not depends on the amp. Your iDevice or Mac will control volume. No idea about Sonos.
What I do for audio outside the living room is use a small amp in the zone with an APE. The Parasound Zamp has signal-sensing turn-on, and has worked well for me. I'm sure there are other options, too. Some may be cheaper and just as good.
post #3 of 3
Thanks. So four separate AEs attached to four separate mini amps (like a T-amp)? Could I drive 4 speaks off of one mini amp if I decided to add another set of speakers in one of the rooms (since it's a big room)?
Also, if anyone has any suggestions on in ceiling speakers, that would be great. I need to replace a few of them. I'm not looking for thumping, super high quality sound, just something good.
