AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › How do you extend the range of a WiFi Router?
post #1 of 5
Do some WiFi-N routers provide better range than others? And is it possible to extend the range of a WiFi signal around the house without repeaters, etc? I have a D-Link DIR625, is it outdated now and should I upgrade?
post #2 of 5
Netgear's higher end routers starting with the WNDR4500, WNDR4700, r6200 and r6300 all have higher powered RF amplifiers then standard grade routers. In addition the routers I just listed use 3 radio technology and Beam Forming technology that also increase range due to the way in which it can communicate with the client devices. The WNDR4500/4700 are N routers. The r6300/6200 are AC and N routers. AC standard is the state of the art today and will allow 1gb transfer speeds. This is near equivalent to gigabit ethernet. The AC standard is still not final but close.
I have written reviews on all these routers. Please see the links below.
WNDR4700 review
http://www.avsforum.com/t/1444918/new-netgear-centria-wndr4700-all-in-one-router-and-nas-review
WNDR4500 review
http://www.avsforum.com/t/1360419/comparison-of-new-netgear-wndr3800-and-wndr4500
R6300 review
http://www.avsforum.com/t/1411661/netgear-r6300-r6100-gigabit-802-11ac-wireless-routers-thread
If you want to extend range beyond what these routers will provide you either need to add and access point or a range extender. The access point is the best solution as it provides no performance hit but requires a hard wire connection to the main router. If that isnt practical then you need to use a repeater. The repeater basically wirelessly links to your main wireless network and can repeat its signal. The issues up until now is you are using the single band (ie 2.4ghz) to send and receive. This adds double duty to it and as result takes a performance hit. Netgear recently introduced a dual band repeater the WN3500RP that can send on 1 band (say 2.4ghz and receive on the other band 5ghz) Now for this to work your main router must be dual band which the 4 I listed are.
You can read my review on the 3500 here.
http://www.avsforum.com/t/1462152/a-great-wifi-range-extender-solution-netgear-wn3500rp-dual-band-wifi-extender-with-fastlane-technology-and-apple-airplay
The Netgear routers and repeaters are excellent products that I am sure will satisfy your needs. I have first hand experience using them in my 3000 sq ft home. Again please read the reviews for more info.
I hope this helps you.
Bob Silver
Netgear AV Consultant
post #3 of 5
So based on the post, I assume you have coverage issues? Where is the router relative to everything else? Is it possible to move the router to a different room to provide better coverage? What else do you have that uses 2.4 GHz? (cordless phones, baby monitors, etc) It's possible that changing channels may help. (would also need to see what channels your neighbors are using)
Just throwing some questions out there... maybe it saves you from buying a new router. (unless you really want a new router) I think that DLink has external antennas, if so, you may be able to get away with a higher gain antenna.
post #4 of 5
Some routers like my netgear wndr3700 v2 can have better antennas added on. I have that as the main router another 3700 repeating with an ethernet connection on the other side of the house. And a linksys wrt54g in the garage to wireless repeat for outside. There is more reason why I split up everything this way but adding just the antennas made a pretty big difference.
Sent from my EVO using Tapatalk 2
post #5 of 5
I have been very happy replacing two older Linksys wireless N routers (running Tomato and using WDS to extend the range of the first router) with a single Asus RT66U. The Asus gave better coverage throughout our house and 1 acre property than the 2 older routers using WDS - not only much better range but much higher throughput at long range.
Review here including wireless performance http://www.smallnetbuilder.com/wireless/wireless-reviews/31687-asus-rt-n66u-dark-knight-dual-band-wireless-n900-gigabit-router-reviewed
