AVS › AVS Forum › Other Areas of Interest › Camcorders › Help me please, video camera
post #1 of 7
Hi All
I have had no luck buying my last two video cameras, fist i bought the panasonic hdc tm15, was dissapointed in that one then i wanted one with a hdd so i bought the panasonic hdc hs80 but again the quality was no good it was freazeing at times and like zig zag lines on the edges of white on my video, can you please give me some advice of what one to get prefered with a hdd .
THANKS ALKING
post #2 of 7
No more "hard discs" on camcorders, for a good reason: they break and memory is cheap. You can get a 64GB sd card for $45. So, now you can choose any brand and level of camcorder you want (some take two cards and relay - seamlessly record across cards as you shoot).
post #3 of 7
Cheers what is a good quality vido camrea to get ?
post #4 of 7
"zig-zag lines" probably require deinterlacing to watch on YouTube. How does it look when you watch directly from the camcorder on a TV? Use HDMI cable for HD quality.
post #5 of 7
I think you should give Sony Cameras a try. The Sony HDR-SR11 10.2-MP 60GB has a great image for its price range. The Sony PJ710 is also a nice choice. Both are capable of taking ScanDisk format cards and the PJ710 even has a built-in projector to view larger images on the go. so you don't have any regrets, try renting one first to see if you like it.
Ben
Lead AV Tech,AA Rental
post #6 of 7
Originally Posted by alking26 View Post
Hi All
THANKS ALKING
1. Get better hardware and software to avoid "freazeing".
2. Learn about interlacing and de-interlacing to avoid "zig zag lines". Alternatively, get a camera that shoots in progressive mode to avoid dealing with "zig zag lines" altogether.
3. Teach yourself and make an informed choice.
4. Do not listen to a "lead AV tech" who pushes a five-year old interlaced-only HDD-based camcorder.
post #7 of 7
Yeah but those "ScanDisk format" cards are really something...
  Back to Forum: Camcorders
