AVS › AVS Forum › Audio › Speakers › NE Spring Speaker Shootout results thread - April 13, 2013
NE Spring Speaker Shootout results thread - April 13, 2013 - Page 19
post #541 of 568
Originally Posted by NWCgrad View Post
I could pack you some fried tarantulas, crickets, and some sort of gross looking inch long larvae. I tried the tarantula, was not good (leathery and hairy). Not as good as 5 guys.
post #542 of 568
Does anyone know if the Behringer EP4000 amp runs in 230V? Is there a switch to change from 110/230? I am thinking of using them to power my JTR Noesis.
post #543 of 568
Don't believe there is a switch.
post #544 of 568
Here are the specs.
http://www.behringer.com/assets/ep2000_p0a38_m_en.pdf
It looks like it will run on 230 V power. It is a German product, so it should, but I can not be certain that there are not two versions and that you don't have to buy the 230 V one.
post #545 of 568
Originally Posted by Jedirun View Post
Here are the specs.
Since there are no switches (see above), I am guessing there are 2 models.
The next question then would be, where do I get the 240V version? I am sure Amazon would be selling the 110V version
post #546 of 568
My guess is that it has a power supply that works with either voltage like most PC power supplies so there may not be a separate product, but of course, I can't be sure.
post #547 of 568
Has anyone heard Klipsch RF-83s and can comment on how they compare to the speakers at the shootout, particularly for HT?
post #548 of 568
I would assume that they would sound almost identical to the rf 82 except with more low end extension. On a side note the tweeter in the rf 83 is slightly larger which pushes the crossover slightly lower. The slightly larger tweeter may reduce some of the brightness people complain about.
post #549 of 568
Would they be comparable to some of the speakers at the shootout? I understand the Cats and the Noesis would be above, but what about the others?
post #550 of 568
Originally Posted by Gorilla83 View Post
Another GTG soon?
That's great Drew, you sure do keep busy!! Looks good. We will all be over in September tongue.gif
post #551 of 568
Thank you sir. As I already pointed to you, I've done quite a few updates since the GTG. Full list:
L/C/R yorkville front stage (Center is only new speaker here though)
Crown XLS2000 for mains
False wall build
AT screen build
Riser - build, stuff, and carpet
Front wall treatments x 4
New AV cabinet for main room (build and paint)
Rough out drywall and construct auxillary AV cabinet in bathroom - build, frame, trim, paint
Swap clone amp for Peavey 7500s x 2
Swap minidsp 2x4 for 10x10
Add oppo 93
Rearrange subs and rewire (re-run wires) for 4 discrete channels
Add Roku media player
Finish/Paint/Assemble new side surrounds (DIY SEOS)
Build 2nd relay box for 2nd amp
Move rear surrounds back for new seating with new wiring
Add to upstairs setup:
-Swap definitive BP30s for DIY Sentinels
-build 2 X SI 18s
-Swap Yamaha receiver for Onkyo 818
-Rewire entire cabinet with new wall plates and wiring for sub amp in 2nd room
post #552 of 568
post #553 of 568
How many beers during that upgrade?
post #554 of 568
Any plans for a black ceiling? I don't know how easily those tiles could be painted and if not that would be a big cost obviously.
I'm still not convinced I need it... still I did have seconds thoughts when ordering GIK panels for the ceiling yesterday. I went ahead with white knowing one day I might be kicking my self if I ever want to paint the ceiling black.
post #555 of 568
Actually I think only one or two! Too busy for drinking. biggrin.gif Now it's time to relax and enjoy though.
The downside to painting (other than being permanent) is that the panels actually have some decent absorption properties to them and painting them would seal them up quite a bit. I've been thinking about building a panel that would cover that area of the ceiling and wrapping it in triple black velvet. This would give me the option to try it out and remove if I don't like it without a permanent change. Not sure how much of a difference it would make, but I'm sure I will experiment at some point. biggrin.gif
Another option would be to cover a bunch of 2x4 acoustic panels and double wrap them in black speaker cloth. Hmm.
post #556 of 568
post #557 of 568
Originally Posted by JimWilson View Post
Actually, I have another plan...pics to follow sometime this weekend. biggrin.gifbiggrin.gif I've got the theater where I really enjoy it now so for now it's time for another project....
The wife and I had been contemplating for the past year or so in installing some type of shed in the yard for additional storage. Since my DIY interest has grown wild in the last year or so, we figured since we're getting serious about this project why not make it a combination workshop/storage type area. In typical Gorilla fashion, the scope of the project quickly went from reasonable to what some would consider excessive. We placed a deposit for the builder last Saturday. I'm looking at a 5 week or so lead time, but meanwhile here is a sneak peek at the specs for now for those interested - pics to follow in a few weeks.
-Exterior size: 32L x 12W x 10H
-7' side walls with roof pitched to 10' for overhead storage
-Vinyl siding and window trim, matched to the house
-5 x 24" X 32" double pane windows with shutters to match the house
-6'8" steel reinforced and insulated double doors on one end toward the house, single door in middle (matching), both with 9-lite windows
-Skylight/window above the single door
-Gable overhangs
-Dormers
-Ridge vented for insulation / HVAC
-4x4 pressure treated frame, reinforced floors with 10" on center floor joists (built to handle rail cars from trains)
-Built in 12' wide workbench on the far end away from the double doors
Future plans include full insulation, electric, propane heating system, a 'loft' for overhead storage', and a 5x10 CNC table with all the gadgets. I'll be wiring the electric including a 100A subpanel with 3 x 20A 120V lines and 1 X 30A 240 line for the CNC.
Unfortunately funding this project means selling one of the toy cars. In all honesty I don't mind since I'd get far more use of of this.
post #558 of 568
Well, if I ever try my hand at DIY I know who I'm asking to build the enclosure. tongue.gif
post #559 of 568
You mean "when" you finally sack up and do a DIY project, right? biggrin.gif
I've become obsessed with the CNC stuff. Spending a bit of time on CNC zone and talking to various folks. Learning as much as a I can at this point. tongue.gif
post #560 of 568
-Gable overhangs
-Dormers
How many subs will be in the workshop?
post #561 of 568
I have an order going into ATS today for about 8-12 2x4 panels that I am going to have them do to my specs. So I can probably comment on all that after I get them in smile.gif
A single port from the main HT room into the shed outa do it biggrin.gif or 8 more subs in the shed with a single port into the HT room? Hmm
post #562 of 568
To be determined. I know I'll be planning a SEOS build of some sort - preferably something full range capable to get me started until subs come into play. tongue.gif
Looking forward to your thoughts B. ATS sells those panels for little profit, almost not even worth building them yourself. smile.gif
post #563 of 568
-Gable overhangs
-Dormers
Just big enough for the horn sub build I predict in you future.cool.giftongue.gif
post #564 of 568
Another GTG soon?
Well I was a little late with the invite based on this original post but can't wait for the next event. Reading through the recap of this event this morning got me even more excited for the next. biggrin.gif
post #565 of 568
Can't believe I missed this!!! Freaking car!
Hope I can come out for the next one!
post #566 of 568
bump, for anybody needing comparisons with SEOS and some commercial products.
post #567 of 568
post #568 of 568
  Back to Forum: Speakers
