AVS › AVS Forum › Audio › Soundbars › Sony HT-CT 150 Sound Problems
post #1 of 3
I have a Sony CT 150 connected to an LG TV and a Comcast DVR cable box via a digital optical cord directly from the TV to the Sony. The sound bar delivers great sound, except that from time to time, the sound "gets stuck" -- replaying the same short sound burst over and over again. If I was watching live TV, I usually have to change channels to get the audio back to normal. If playing a program from the DVR, I usually have to stop the DVR and then change channels. Sometimes I have to change channels on the cable box several times. Anyone run into the same problem? Any solutions?
post #2 of 3
I don't recall anyone ever posting that particular problem before. Wondering why you are connected the way you are though. Why not connect the cable box directly to the CT-150 via HDMI and then run another HDMI out from the CT-150 to the TV? At the very least, you could try that to see if it eliminates your audio problem.
post #3 of 3
That's exactly what I would do.
  Back to Forum: Soundbars
