AVS › AVS Forum › Audio › DIY Speakers and Subs › Error message when entering Ts parameters in winisd pro
post #1 of 7
I can't seem to get them right Any one have the download file? SI 18 D2
Edited by deathinc - 4/15/13 at 10:57pm
post #2 of 7
You're putting in too much information. Only enter Qes, Qms, Fs, Vas, Mms, Re, xmax and Pe, let the program calculate the rest.
post #3 of 7
For what driver?
First enter Mms, then Fs. Click on Cms then Fs again. Enter Sd, Bl, and Re. Enter Qms and click on Rms then Qms again. Enter Xmax and Pe. Save file.
post #4 of 7
it also errors if u enter qes and qms as the same value
post #5 of 7
As it should, since it's virtually impossible for those figures to be the same.
post #6 of 7
Stereo Integrity SI 18HT D2_Data Bass.zip 1k .zip file
I used the TSp's from Data Bass. iirc, these were the specs most guys were using early on in the SI pre-order thread, but you should verify yourself.
post #7 of 7
The winisd help system has a page about how to enter a new driver, too -- basically the same thing these guys are telling you with a few additional details.
-Max
