AVS › AVS Forum › Audio › Speakers › Speaker Recommendation
post #1 of 7
I am needing some fronts for a very large room.
- Room 25x25x20
- Prefer to not get towers (not very visually appealing)
- $200 range
- Mostly for music
- Sub will be added later
post #2 of 7
What kind of power do you have? Meaning are you using an integrated Stereo Amp or a Home theater receiver?
post #3 of 7
It will be a 7.1 receiver, about 90W.
post #4 of 7
I would say the BIC acoustec HT-64. Buy it at Overstock for $220 or shoot BIC an offer of 200 and see if they accept.
I say this because yours is a big room and those speakers are very efficient, meaning they will get very loud even with a lower power receiver. If it says 90watts "on the box" it is probably closer to 30 or 40 unless it is one of a few select brands that advertise their true outputs... but I digress.
Those speakers will really rock!
post #5 of 7
http://www.avsforum.com/t/1464265/looking-to-buy-some-high-sensitivity-bookshelf-speakers#post_23102508
post #6 of 7
Hrmm....so with that said maybe ill push my budget a bit more. I started looking into some of the speakers on this list:
http://www.avsforum.com/t/1387083/list-of-reference-level-high-sensitivity-spl-speakers
What about these choices? Anything better? How will the kits compare to hsu?
http://www.hsuresearch.com/products/hb-1.html
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion-series-kits/fusion8-kit.html
http://www.diysoundgroup.com/karma10-kit.html
post #7 of 7
You should start a thread in this forum if you want advice on kits: http://www.avsforum.com/f/155/diy-speakers-and-subs
Check this thread for some info on the Fusion 8: http://www.avsforum.com/t/1468211/ne-spring-speaker-shootout-results-thread-april-13-2013#post_23202132
"7) Fusion 8 – Alchemy – DIY", other members also posted reviews.
  Back to Forum: Speakers
