AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Best converter for recording from Comcast to DVD Recorder?
post #1 of 9
I am looking for a product that will transmit an HDMI signal from a Comcast cable box to a DVD Recorder with av or component input. Does such a device exist? If so, can I be pointed in the right direction? Much thanks!
post #2 of 9
DVD recorders use composite or S-Video for recording, no component in. If you're looking to convert HDMI or component to composite then this will work.
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=7114&seq=1&format=2
All recordings will be in SD only.
post #3 of 9
Technically, a few DVD recorders with component do exist, like the Polaroid 2001G. But it's the worst DVD recorder I've ever had.
Why not skip the cable box altogether and get full HD recordings using a cable card tuner? It's cheap and works far better than a DVD recorder.
post #4 of 9
A thread talking about HDMI to component or S-video converters.
http://www.avsforum.com/t/1335030/hdmi-to-component-or-s-video-composite-converters
post #5 of 9
Doesn't your cable box have composite and/or component outputs? I have, and use, an HDMI to composite/S-Video converter. It works, but isn't great. The composite output of my DirecTV box is far superior to the output of the converter.
I got mine from Monoprice, but they don't carry it any more, or at least, I can't find it there anymore. It looks exactly like this one.
post #6 of 9
most boxes out there that i have seen don't keep the widescreen flag on the SD outputs. Especially with those of us that record sports, it is a big drawback
Only NBC/NBC Sports network i believe still full screen their sports.
I, too, am in the market for one, and am surprised that I couldn't find it on Monoprice
post #7 of 9
I find this statement confusing. My DVD recorders do not record onto the DVDs the WS flag, and the presence or absence of the WS flag has no impact on my TV watching at all. I set my television to stretch, and the anamorphicaly recorded programs are in the proper aspect ratio. When I have a genuine 4:3 program, I set the TV aspect for 4:3 and again, the proper aspect ratio is displayed. The only time the WS flag is of any consequence is if you record 16:9 content and play it on a 4:3 television. Without the flag, the DVD player doesn't know to letterbox the content to maintain the aspect ratio.
Are you recording widescreen sports and then playing them back on a 4:3 television?
post #8 of 9
I don't think it is really a matter of a WS flag. Most cable boxes assume that the analog composite/S-video outputs of their STB will be going to a legacy 4:3 TV since those outputs are incapable of transmitting HD. Hence they format the output for a 4:3 display by either clipping the 16:9 to 4:3 or letter boxing the 16:9 into a 4:3 frame with black bars above and below. This is a perfect arrangement for their customers who plug the box into their legacy TV but not so good for those who want to plug their box into a recorder with the intent of playback on a 16:9 display. Thus the need for a converter, and its negative impact on PQ, in order to record in the proper aspect ratio.
It's hard to see how one could win with a DVD recorder when being forced to record off a cable STB.
Edited by Kelson - 6/10/13 at 6:16am
post #9 of 9
My solution is to use the component out of my cable box, then use a converter to s-video, which prevents black bars on top/bottom
It's been a success
  Back to Forum: DVD Recorders (Standard Def)
