AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 2113ci streaming from PC
post #1 of 3
Hi Everyone. I'm new here and have a question I'm hoping someone can help me with. I have a new Denon 2113ci receiver. I can play music from my PC through the network setting but was wondering if there's any way to control the music from my PC? I would like to set up playlists in Windows Media Player and then run them through the Denon. I also want to play games through this. I know that I can set up an additional cable to one of the inputs that will handle both but if I can do it with one cable it will make the setup cleaner.
-Brian
post #2 of 3
It's pretty simple. All you need is an HDMI cable or optical cable (depending on what you have available with your PC) connection.
post #3 of 3
I have an optical cable. What I'm trying to do is use the network connection to avoid running two cables. Is that possible for games? I figured out that in WIndows Media Player I can right click on something and play it on the Denon. I can also save a playlist and then select it from the receiver. I can't see any way to do this other than Windows Media Player though which eliminates games.
