AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › EPSON 5020 Crooked picture although level??????
post #1 of 3
Hey guys,
I have a few month old Epson 5020, ceiling mounted PJ with an approx 90 inch screen. PJ is mounted dead center on the screen and just about even with the top of the screen, give or take. I installed it a few months ago but really have not had a chance to use it much. Now I am noticing that the picture looks crooked on the bottom, but not the top?
My screen is 16:9 and with a 2:35 movie in, the top is even but the bottom looks crooked like the PJ is slanted. I checked and the screen is level. If I leve the bottom, the top becomes uneven???
Am i nuts?
This is my 3rd PJ in this set up over about 10 years or so, never had this problem? Am I missing something. I don't remember this happening on the first few blu rays I watched.
Brian
post #2 of 3
I sounds like you need to rotate your projector and use the lens shift.  The projector needs to be perfectly facing the screen, it sound like it is slightly rotated and you aligned with horizontal lens shift.  Should be an easy correction.
post #3 of 3
Ah, never thought of that, thanks so much. I will try it tonight when I get home.
Brian
