AVS › AVS Forum › Audio › Audio theory, Setup and Chat › volume control with 2 sets of speakers
post #1 of 5
I am about to wire my outdoor patio and hope you can answer this question. My patio has two distinct sitting areas that I hope to put 4 speakers (2 sets of 2) in, but my AVR only has 1 zone to work with. I plan to control the amp via my wifi network. i plan to simply fork each of the red and black at the amp and make runs to the respective patio areas. Hopefully that is simple enough. However, I was thinking about putting in a volume control at one of the patio areas (the less used area). is this ok to do? my rationale for this is that usually all 4 speakers would be on simultaneously, and could be controlled generally via my phone app. but in certain instances, i might want to lower the volume to the second patio area independently. Any thoughts?
post #2 of 5
Yes, make sure you use 8 ohm or higher impedence speakers (so the parallel combo is still 4 ohm), and add a volume pot to the circuit between the loud and soft areas.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-264
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-260
Where the connection diagram shows "to amp or crossover" is where the other zone speakers are connected, in parallel, to these and the amp.
HAve fun,
Frank
post #3 of 5
Thanks. I didn't know that existed. However, that doesn't look "outdoor ready" to me. what would happen if i just hooked up a volume switch to one of the cable runs? from the sounds of it, the impedence would be a bit off, but is that going to damage my equipment or seriously reduce sound quality? sorry, audio newbie here.
post #4 of 5
you cannot use a line level volume control in line with a speaker. It's not expecting to ever see a watt, so when you hit it with 10 watts, it will die promptly.
The L Pad from parts express is buitl to be mounted in something. You can pick up a simple project box and wire it up so that there are banana plug ins and outs, or whatever you want, but I wouldn't use the thing 'naked" because there'll be significant power present sometimes and a person could get hurt if they touched the electrically hot parts . . .
post #5 of 5
Yes, you'll need to integrate the volume control into your layout, a project box or panel mount of some sort. I had assumed you might wall mount it near one set of speakers, and I'd need some pictures to suggest anything more. An L-pad will maintain the same amplifier load, regardless the setting, allowing you to control the second speaker independently, but it'll never get louder than the first pair.
Have fun,
Frank
