AVS › AVS Forum › Display Devices › Screens › da lite model b with csr high power screen have waves.
post #1 of 5
Hi guy,
My da lite model b with csr function that is using high power screen starting to have waves on it, so should i contact da lite for replacement? as i know high power screen is not effected by waves but in long term using it should i be worry? Thanks
post #2 of 5
ALL non-tensioned pull downs eventually develop waves.  However, the waves on a HP is typically not that noticeable with viewing material compared to some other materials.  If you are noticing the waves with viewing material on the HP it might be worth giving Da-lite a call.
post #3 of 5
So far did not notice the waves during movie viewing but will i be seeing waves in near future?
Edited by squall12 - 4/19/13 at 2:21am
post #4 of 5
You might if you look for them or on large bright areas of mostly a solid color, like shots of the sky or an icy/ snowy landscape.  But, most of the time you will not notice with that screen.
post #5 of 5
ok Thanks BobL.
  Back to Forum: Screens
