AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › F25 / XS30 !?
F25 / XS30 !?
post #1 of 7
i was wondering how different both of those 'dual sub' would be .. i know they are both sealed and have almost the amp , so i guess they should be pretty similar no? ive been looking around for some spec or mesurement ..no luck , have not found any !
they are both in the target to buy for me... size wise they are similar since i will probly be laying the f25 on the side if i buy this one .
anyway if any of u guys have any idea how they perform compared to each other , let me know !
post #2 of 7
Uncertain how they would compare but I think you are thinking of the Power Sound XS30 rather than the XV30 as the XV30 is ported rather than sealed.
post #3 of 7
i wish i could change the title !!! i meant XS30 !!!!!
Edit : title changed ! found out how !
Edited by nemoreborn - 4/19/13 at 3:05am
post #4 of 7
the xs30 and f25 are nowhere near the same size...
xs30- 23.5" x 18" x 22.5" (d,w,h) 111lbs
f25- 23" x 19" x 33" (d,w,h) 140lbs
post #5 of 7
Nemoreborn, I assume the f25 is a rythmik sub? And the xs30 Is what brand? See my profile photos , notice my two rhythmic f25 subs up front . I made DIY'ed the cabinets so they could be laid on there side, Brian at rythmik , had concerns about the amps orientation. He said the amp needs to be up right. They are really articulate subs powerful with plenty of headroom,they easily keep up with my JTR t12's up front. I also have two f15 at the rear. All are sealed great subs.
post #6 of 7
... And the xs30 Is what brand?
Power Sound Audio (PSA)
post #7 of 7
Thanks eljay, I'll have to check em out.
