AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The retirement dream home theater
The retirement dream home theater - Page 12
post #331 of 368
Nice new ride Bill!
post #332 of 368
thanks Dave I bought my 2002 new and had her 11 years. hopefully the next guy will enjoy her as much as I do. The 2014 is a sweet ride! biggrin.gif
post #333 of 368
post #334 of 368
That looks amazing Bill!
We had Rainbow when our little one was younger and while it wasn't cheap, we got our money's worth out of it.
post #335 of 368
Thanks it does not get cold too often here in GA. (I mean bone chilling) but that did not stop them from wanting to go out. smile.gif
post #336 of 368
I may have missed it, but did you do any sound proofing for your floor? I'm trying to determine what to do for my 2nd floor bonus room in that area.
post #337 of 368
Originally Posted by cw5billwade View Post
Going way back but do you know where this pic is from? My wife would like something like this for my theater so I'm hoping there is a build thread for it.
post #338 of 368
My build is above the garage I am not calling it a bonus room because I designed the house (along with builder and architect) for that area to be a theater. I lowered the roof of the workshop to accommodate the front of the theater to be 12” lower than the rear which is on level with the rest of the upstairs. In the first few pages of my thread you will see I used acoustical caulk in all of the cracks and holes between the garage and the theater. We also installed a second subfloor of ¾” Tung & Grove OSB using green glue and again every crack had acoustical caulk. The ceiling of the garage was spray foam and I had electrician put putty pads on the light fixtures and outlet for the openers. If there was living space down there I would have used R19 vise the spray foam and did a DW/GG/DW on the ceiling of that space with IB-1 clips.
caulk in garage
you can see the caulk here
Here you can see the green glue on the 3/4" T&G and also the caulk on orginal sub floor and second sub floor going in.
we also put OSB on the 2x12 used to lower the work shop ceiling
pile of T&G
spray foam
caulk on second sub floor
I did not take picture of putty pad in garage ceiling but here is one in the wall between theater and billiard room
I will have to see if I can find it. It may have been in the show me your completed room thread and the person did not have his build linked in his name
Edited by cw5billwade - 1/28/14 at 6:12am
post #339 of 368
here are some you can show her still looking for the other
http://www.avsforum.com/t/1061114/show-me-your-completed-theater/600#post_22463117
http://www.avsforum.com/t/1385501/jautors-rock-creek-theater-a-post-build-retrospective
Edited by cw5billwade - 1/28/14 at 8:05pm
post #340 of 368
Thanks! These are great pictures! Also, thanks for the insulation recap.
post #341 of 368
Well did I say I lived in the south can't tell by looking out the window. eek.gif 3" of snow in the south you do not go to school or work. biggrin.gif
post #342 of 368
more
we played the drinking game during the state of the union address. Every time there was a standing ovation or other key words we had to drink.
post #343 of 368
We have the same here in Charlotte, or dare I say a bit more on the ground. All is good, though. It will be gone by the weekend.
post #344 of 368
I sure do miss Hawaii but was fun watch grand kids
post #345 of 368
On to the equipment rack in my media room. My rack is a little different than most that you see as I wanted to also support my data entrance point in my media room so I made a L shaped shelf under the opening for the rack that wrapped around under the media entry panel. I than used the metal shelves that you by from HD or Lowes that have the triangle shaped shelf supports. I than fashioned another shelf from the bottom of the media entry panel around to the rack.
We cut the shelves and used biscuit joints and kregg screws to make the shelfs. I gave enough clearance for ventilation to install my old Pioneer 818 AVR to power my speakers on the back porch and my work shop and my new Denon X4000 AVR into the rack along with my other toys like my power management center and Panasonic Blue Ray etc.
cw5billwade,
Been awhile since I checked in on your build - looking good (and a nice upgrade on the Stang!)
I need to mention that you had a clever way to pass the time with the State of the Nation Address last night, I need to try that next year biggrin.gif
So since I last checked in on you; I have been enlisted to assist my brother with his build, and have a question about ideas I intend to "borrow" from your build.
In the photo above I am curious of the dimension of your AV equipment shelving.
Also what thickness of shelf material ( I have also been looking at the pre-laminated shelving, but am concerned that these might bow or sag?
Now that yours have been in use any concerns or suggestions?
Also; it looks like you took the longer shelf support brackets and cut them back and perhaps drilled some holes thru them to better "lock" the shelf to the bracket form the underside..?
Thanks in Advance!
Craig
post #346 of 368
Originally Posted by cuzed2 View Post
cw5billwade,
3/4" MDF which is what they use for shelves in the closets and pantry so no concern with sagging
You can buy smaller brackets come in different sizes. My friend gave me these from something he tore out. So no need to by them I did trim them to suite my needs and drilled a new hole to secure the shelves. The shelves cantilever out the opening and the front 5" of shelf has no support under it. You just want to secure the shelf so if you have a piece of gear which will have more weight on the front 5”. For most gear that is 14" deep there is no problem.
Thanks in Advance!
Craig
Hey Craig Glad you checked in. I made the opening 21” so that after the builder trimmed it out with 3/4" MDF it would have a 19 1/2" opening. Just seemed to be the size most racks are so I went with that. Not all my shelving is laminated MDF just the parts that you can see from the Billiard room and the up rights. I used some regular MDF on the media side from the pieces left over from the window plug. The Laminated MDF was just some old shelves I had laying around. Both the shelves and the other MDF I used were 3/4" I used the biscuit joiner and the Krieg screw kit to build the entire thing.
First I built the uprights each one had 2 pieces of the laminated shelf that I joined with the biscuit and Krieg Screws. You have to run the ends that you are joining through the table saw because the biscuit and glue does not play nice with the laminated ends. I had to notch the bottom so as to go around the base boards. You can see the ends of the 3” MDF strips I used under the shelving. I also ran these strips along the wall ensuring to hit the studs with the 2” nails from my finishing nail gun.
There were 2 long shelves that wrapped the corner. The top one was just below the media entry point which I bought from Smart Home. I put my 3 “strip of MDF 3/4" down from the media entry point so the shelf would line up with the bottom. The bottom one was 1 1/2" above where I spliced the two uprights together. This was so that when I nailed the 3” strips to the up rights (using a 1 ¼” braded nail gun) it would further reinforce the uprights. (not sure they needed it the biscuits with Krieg screws were plenty strong) You have to insure that your shelving racks are level from side to side before you fasten them. They went on after the Bottom shelf was built. Then I put the top L shaped shelf in which was notched for the opening and to go around the shelf racks. Bottom shelf was solid piece of MDF top shelf was made from splicing the laminated and plane MDF with biscuits and Krieg screws. The bottom AV shelf sits directly on the bottom of my opening. You can see how I notched the shelves 5 1/4" so that they would slide fully into the opening and account for the shelf racks. Again wood glue biscuits and Krieg screws made all the shelves. And I used a mess of the 2” finishing nails on the 3 “strips on the wall and the 1 1/4" nails on the 3” strips on the up rights (from both sides). Some times when I am in the building mode I forget to take pictures.
Edited by cw5billwade - 1/30/14 at 9:49am
post #347 of 368
House covered in snow snow on roof means spray foam works!
Me and the grand kids getting ready for snow ball fight
We made a snow man I had to take some pain pills after LOL
They really let Kevin have it. The rule was no snow balls thrown at Pap Pap
snow angles
post #348 of 368
Thank You - Quite helpful!
We are going with a finished opening 20" wide
So it seems that the laminated 3/4" MDF is plenty sturdy for those shorter AV equipment shelves?
I'll have to look around to see where I can find some (stuff I originally saw was 1/2' laminated particle board - and that worries me as not being strong enough)
Craig
post #349 of 368
Craig
I would not use 1/2"
post #350 of 368
Agreed. Depending on the dimensions, that stuff loves to warp under load, over time.
post #351 of 368
Thanks Guys!
If I can't find 3/4" laminated MDF of my liking;
I will probably go with 3/4" oak plywood and veneer the edge(s)
post #352 of 368
Definitely use 3/4" of whatever wood you choose. 1/2" is too small unless you are going to use steel shelves smile.gif
post #353 of 368
Got my right SI joints done today so I guess since I can not work up there I will be watching another marathon. What to watch?
post #354 of 368
Lord of the Rings Extended Editions on Blu Ray + Hobbit part 1
Star Wars (6 movies)
Terminator Anthology
Alien Anthology
post #355 of 368
+1 Burne notice?
post #356 of 368
my daughter who is a stay at my home mom ( they live with us) said Pirates of the Caribbean
post #357 of 368
Well what follows a snow storm a week latter you ask 3" of ice and no power for 3 1/2 days
Grand kids staying warm
Darn glad I went with the gas logs and not the electric fire place the contractor was talking about. It would have been unbearable cold in the house.
This is me the last two weekends cutting all the limbs and fallen trees and dragging them to the road for the county to take off. The white pine down here really does not like the ice. I got my money’s worth out of the John deere mower and the trailer for sure.
post #358 of 368
Hi there - just popped over from the thread you have been helping me with. Great project you are on here.  Must say we have had the rain in Cornwall... but no snow. Mind you today shows some signs of Spring. Many thanks for your help on my project. I will follow the links you gave me.
As far as bunkers go... I am waiting on those Tornadoes!
post #359 of 368
yea I did not use any provisional design service or anything I just took what I learned from the very well documented build threads here made some calls to sound proofing company and went from there. I think the soundproofing is not an issue and you only need to look at the acoustical properties. i.e. stuff stage with sand, stuff the riser with insulation. I would do full front and back of room like I did and then figure out where you need them on the side walls.
post #360 of 368
Oh did I mention the 4.5 point earth quake 4 days after the ice storm?
Anyway here are some pictures of the limbs and trees we cleaned up. The County thinks it might be up to 45 days to clear. I am sure they are working from suburbia out to the bunnies
than is my car behind these 5 piles
here is a shot at my other property line I figured I would split up the piles but really just shorter route to road from where I was picking them up.
