AVS › AVS Forum › Audio › DIY Speakers and Subs › What Qualities Would an "Ideal" Subwoofer Amplifier Possess?
post #1 of 88
I am interested in discussing amplifiers that are used to power subwoofers. I have four DIY subs powered by a Crown XTi-2002, wired for 2-ohm operation. I had recently read the Crown I have is less than ideal for sub duty, due to an overly aggressive high-pass filter. After two calls to Crown tech support, I came away convinced Crown does not have much interest in the subwoofer amp segment.
Prior to the Crown, I was running a Behringer iNuke 6000 at 8 ohms. The iNuke's marketing specifically pitches it as an amplifier that is good at reproducing bass frequencies. Both amps do their job reliably, and without stumbling. The question is this: can I do better strictly through amplifier upgrades? If the answer is yes, then what parameters matter most? I have read that one "ideal" amplifier for sub duty is the Lab Gruppen FP10000Q professional amplifier—is there better out there?
I am curious what qualities allow an amplifier to approach the "ideal" for subwoofer duty. Should it play flat to 1Hz? Should each amp be able to handle a 1-ohm load—or a 2-ohm load when bridged? Should the amp's cooling be entirely passive, or is it OK to use a very quiet computer fan? Does damping factor matter? Is it better to have four channels, how about four channels with the option to bridge into two?
Would modularity and expandability be appealing? How about a chassis with a transformer and slots for amplifier modules—three subs? Get three amp modules. Do you have six subs? Get six modules. If you have one great big subwoofer, get two modules and bridge them. Is your sub a dual-opposed 18"? Then try four modules total, bridged into pairs, with one pair powering each driver!
I am curious about output voltages and ultra-low frequencies. Do class D amps have issues with continuous output of infrasonic waves? Is there any advantage to class A amplification for low frequencies since it is the perennial favorite for full-range speakers? How about a dedicated 220 volt line—is that the ticket to real performance?
Finally, how about DSP? Would a stand-alone subwoofer amp capable of performing some kind of room EQ be appealing? What if delay, EQ, phase, high-pass and low-pass filters were all programmable through an app?
Now I know I could leave my amps alone and look at building new subs and/or shopping for upgraded drivers, but I really am more interested in discussing amplification. I've asked a lot of questions, am interested in serious answers. I appreciate any insights into the topic. Thanks in advance for keeping the discussion civil.
Big subs need big amps - photo ©2013 by Mark Henninger
post #2 of 88
Hmm, well lets look at the ideal op-amp. Infinite gain, infinite bandwidth, zero noise and losses. Make that!
In all seriousness, if you can cleanly output from 3-120hz, you're good there!
If the amp is 2-ohm stable, you're good there!
If the amp can do large voltage swings, you're good there!
Class H or D (although D is more efficient), it won't matter, but give is a switch mode power supply with a very neutral power factor. Oh and we still want a lot of capacitance for those large voltage swings (explosions in the movie)
Beyond that, a person can add DSP. I don't know how you'd make it modular without having a huge chassis to add more power modules and some folks won't want a huge 7RU chassis if they only need two channels of amplification instead of six or eight.
Personally, I don't care too much about 2-ohm operation and would like an amp that can do large voltage swings for 4 or 8-ohm operation. I don't want to have 1 or 2-ohm loads run to the amp requiring 8AWG wire to prevent line losses.
post #3 of 88
This thread compares a few real amps with specifications good for sub duty.
http://www.avsforum.com/t/1409681/powersoft-k10-vs-lab-6400-vs-crown-it8k-and-the-winner-is
Ricci uses a Powersoft K10 to power the subs he tests for DataBass.
post #4 of 88
The ideal sub amp will provide the power you need into the load you have, for the entire bandwidth desired at low distortion and noise.
post #5 of 88
A K20, PLM 14K and iT12k is about as close to perfection as there is. (Without weighing 1000lbs and being the size of a beer fridge and require 3-phase LOL).
But they are so expensive that they simply aren't practical for home use, by us peasants.
So The FP14k clone is the next best thing. Unless I'm missing something.
Based on this thread http://www.avsforum.com/t/855865/measuring-amplifiers I purchased an EP4000. It looked great on paper 1.6kW RMS bridged into 20hz@4 for $300 what could go wrong?
but in actual-use the clones smack the EP's around all the way to the horizon. Perhaps efficiency and peak-power was more important than I realised? (I'm still scratching my head over this.)
Someone really needs to measure the clones into various loads.
On a side-note: Do you like the XTI2k better than the nu6k?
post #6 of 88
regulated power supply (power factor correction) in the clone?
into 4 ohms, behringer is 1600 watts. clone is 4400?
not sure about the capacitor reserves, probably more joules in the tank with the clone?
op, instead of reinventing amplification, just take a look at the cv5000 for a low cost pseudo copy of the crest ca18.
post #7 of 88
I will be trying out a new amp soon that can sustain its rated power spec for a solid 5mins not 20ms New indian company. have to wait to middle of May to order. Will be A/B comparison of my Crest 7200 vs their amp that has 1000watts stereo in 4ohms. Cost is about 430 before shipping. They also have an amp that will do 4000watts x 2 4ohm. They are making all sorts of amps soon. Plate amps, four channel amps subwoofer amps that can be tested at DC with bandwidth only going up to 1000hz, does 5000watts mono 2ohm or 4ohm. Was designed for Roots style music. All sub amps are tested at 10hz for rated specs.
Anyways glad to see your still around Mark. I sent you a PM but never heard back. Busy people is all no prob. I am sure others can say more important information pertaining to this thread than I. I only know what I have used and figured out along the way.
post #8 of 88
Gotta site to learn more about these amps?
post #9 of 88
http://www.zypherlabs.com/
I have been chatting with them about various amps over the past few months. They are just a very new company and just starting to hit the Expo's.
post #10 of 88
Thx!
post #11 of 88
I can't find a PM from you, sorry about that. I've kept busy, no doubt about it 2013 is a real change of pace versus the last couple of years. Thank you for the input; subwoofer amps that can just run at maximum unabated, with no real restrictions on how low they can go, seems like a good idea.
post #12 of 88
I have high hopes for this new company after chatting with them for so long. They design their amps then have china build them. Same area as Sanway but not same company. that being said I will learn more when I get my first amp from them. Then I will know if it is true or smoke.
I sent you a pm on the other forum. Will send you one here.
post #13 of 88
Any idea of the expected cost of the 6402 or 8002? What about release dates?
post #14 of 88
In addition, IMO it would have a 12V trigger, NRTL safety certification, and be as small and quiet as possible, and a long warranty valid in the country of purchase. Ideally, it would be cheap as well, but that doesn't seem to go well with the other parts.
FWIW, for a home system the sweet spot for me is the ElectroVoice CPS-8.5. Adequate power and number of channels to run a multisub system with reasonably sized subs (maybe not 15's in 20L cabinets that need massive Linkwitz Transforms), NRTL safety certified, small (8 channels in 2RU), 12V trigger input. Would be better without a fan, but it's small. Also fairly expensive, but it's 8 channels with bridgeable pairs, small, and made in Germany.
For a nearfield system, IMO the sweet spot is the Paradigm X-850, despite the silly spring terminals, because ARC/PBK is sufficiently advanced that it does about as well as extensive measurement-listening-measurement loops, but takes a lot less time. Also has scads of power, NRTL safety certification, 12V trigger, no fan, etc. Again, not cheap, but IMO worth it.
You are. There's no such thing as an "FP14k clone." There's a "counterfeit FP14k" or a "pirate FP14k," perhaps, but not a "clone."
Theft is theft and justifying theft just makes one, at best, an accessory to it.
post #15 of 88
I know the 8002 will be 1400. The 6402 I think was around 1200 but I dont recall. These are just ballpark figures. After Mays shipment they will have a more set price. Because they are a new company I dont want to dump a bunch of money into them so I am going to try their two smaller amplifiers. They are making a 4x150watt amp. That will be about 250-300. The 1000x2 will be about 440. So hopefully they all work just fine. They will be perfect for my outdoor setup.
PLUS I am willing to spend 500-600 dollars on a new company that I have chatted with for quite a while then 900 on the clone. Either way I am excited.
post #16 of 88
PM sent Mark
post #17 of 88
I'm also very interested in reading/hearing more about the 8002. Right up there with FP14K rated power and if this could prove to be a reliable option it would be a huge hit around these parts. Please do keep us posted. biggrin.gif
post #18 of 88
-Long term, sustained, full bandwidth power without built-in filters
-Low impedance stability at high levels
-Ability to run in stereo or bridged configurations
-Very high efficiency and ability to run on 120V a plus
-Integrated DSP would be a plus
-Lightweight a big plus
-Quiet or non existent fans
-12V trigger/relay a big plus for us home theater junkies
-Long term reliability and vendor support
-Low noise floor and adjustable gain
-Ideally American, Canadian, or European made
In the past year I've played quite a bit with the EP4000, inuke6000dsp, XLS5000, various plate amplifiers, and a few of the FP14000 Sanway clones. Each have their advantages but none of them are my ideal amplifier IMO. I'm starting to heavily consider some of the rack mounted amplifiers from speakerpower. No, they aren't cheap but they come highly recommended from some of the top ID speaker manufacturers. They seem to cover most of the bases I'm looking for as well. cool.gif
post #19 of 88
Any info on tested speaker power rack amps? Like where do they drop off at? They look nice but are pricey for sure!
post #20 of 88
There is some info in this thread:
http://www.avsforum.com/t/1449918/new-speakerpower-rack-mounted-subwoofer-amps
I am wondering how the SP2-8000 can be run off 120V and maintain 2400W indefinitely as that would require 40A.
They are very interesting amplifiers, but would prefer more third party measurements, particularly power at 5Hz and distortion levels.
Also, I'm curious how they a pair of LMS 5400 would sound powered by a single SP2-8000.
Only downside is that one could get 3 Lab Clones for the price of a single SP2-8000.
Or one could see it the other way, you could get 2 SP2-8000 for the price of a single real Lab FP14000! biggrin.gif
post #21 of 88
I must'a missed something. 2400W/120V=20A
post #22 of 88
Ok, so correct me if am wrong but it looks like it beats everything down to 12hz as far as roll off added with efficiency? Just the claimed efficiency part alone along with the "Big Boys" that are using these make it look like its worth every penny. Just by "their" claims alone it makes the FP clones look awful as far as sustained power. But if the FP14 has that burst down at 3-4hz and the FP10q has the burst down to 7hz while this one could "theoretically" drop off the table at 11hz then it could get thrown out of the window. Just a spec that hasn't been measured as of yet could really make or break it!
I'd sell my fp10qs and get these if measurements confirmed they could hold just enough of a percentage of their efficiency down where the clones do. The clones must recharge very quickly since the output is clearly shown by users graphs though.
Interesting stuff between it and they Asian amps that are coming. I hate this stuff at times but need new amp for a couple drivers.
post #23 of 88
How much power do you need AVH?
post #24 of 88
I'm very interested in seeing some independent testing of the SP2 amplifiers to verify the claims. I've discussed these amps at length with Jeff P. and Mark S. and they are apparently are the real deal. I've been happy with my FP14K clone for now, but it would be nice to have a long term, reliable solution. The SP2-8000 would seem to fit the bill. cool.gif If we had enough interest, maybe SP would consider a group buy.
It would also be a big plus to open up the DSP controls for us DIY'ers.
post #25 of 88
From what Mark and others have said, the DSP programming for the SP amps is very far from being user friendly, including needing a dedicated hardware box to do the programming. One solution would be if if the minidsp, alldsp, or the Digmoda DSP add on modules were compatible with the speaker power amps. The Alldsp modules are already compatible with the Pascal amp modules, and this would be a nice solution for the Speaker power amps.
I would really like to use the SP1-2400 in an LMS 18 build but would like to have the DSP for response shaping/LT and also for limiting to keep the driver safe. I have a Digmoda 1000 watt amp in my dual opposed AV15 sub and while the DSP is great, and easy to use, the amp would be under-powered for the LMS.
post #26 of 88
I like the flexibility of separate DSP/Amp........ it just seems that they both evolve at different paces. Do onboard DSP's have firmware update ability
post #27 of 88
Right now I have the two Fp10qs running 8 of my 10 with 2000-2100 watts to each driver and have the option of running the 9th on a qsc2450 and tenth on one channel of a QSCplx3602 but that's not working out as there just isn't enough output that way on the last two drivers.
So three of the sp12000 would give me an extra channel and drive all 10 subs at close to a 1000 more watts each.
I don't really need more per driver than I have and could risk another FP10q c but thinking best thing to do is quit supporting them since all the issues lately along with principle.
post #28 of 88
Ya you did. tongue.gif The SP2-8000 is actually stereo so 2x 2400/120 = 40A. biggrin.gif
The SP1-4000 would operate on 20A as it is mono. The SP2-8000 looks like it is simply two SP1-4000 amps in a rackmount configuration.
post #29 of 88
iirc, the "sustained" power from these amps is at about a 30% duty cycle.
post #30 of 88
Wouldnt it be easier to just have all pro amps on 220 lines.
