AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Help: Can't Get 3D to work on JVC RS45 when connected to Pioneer Elite SC35 Receiver
post #1 of 4
I finally ordered my 3D emitter and 2 pair of glasses for my JVC RS45 projector. After connecting the emitter and pairing the glasses I inserted "The Amazing Spiderman 3D" and was promptly met with the following message:
3D EXPERIENCE REQUIRES 3D ENABLED TV & PLAYER
My connection is Projector to receiver (Pioneer Elite SC35) via a 35ft HDMI (High Speed with Ethernet) cable. My blu-ray player is the PS3. 3D settings in the projector are set correctly, but on my PS3 I have been unable to select the 1080p video output setting. I did do a direct connection from my PS3 to projector with a short High Speed (no ethernet) HDMI cable and was able to select the 1080p video output settings of which the 3D signal and movie works perfectly. The issue appears to be my connection through the receiver.
Does anyone know if there are issues with using an HDMI cable with Ethernet through a receiver? I thought I read that somewhere it could be an issue. Or if it could be the long run as the issue? Or if there is an issue with the receiver?
Any help would be greatly appreciated.
Thanks in advance.
Dale
post #2 of 4
The problem was the cable. I don't know if I got a bad cable or if it is indeed a compatibility issue with the ethernet portion of the cable but the new cable I bought was a High Speed cable and it works fine.
post #3 of 4
post #4 of 4
Me too! Thanks Mike.
