AVS › AVS Forum › Audio › Receivers, Amps, and Processors › connect wireless mic AVR-2313CI
post #1 of 6
I have a Macbook pro and a DVD player connected, via HDMI inputs, to my AVR-2313CI. I want to connect a wireless microphone and listen to the mic input while watching the macbook pro screen. Is it possible?
Carlos San Miguel
post #2 of 6
Sure. If the wireless mic has an output comparable to the 2313CI inputs.
post #3 of 6
Assuming I find a wireless mic that send the signal to a box that is connected to the AVR with an HDMI cable. The AVR can take the sound from one hdmi port and the video from another? Is that corretc?
post #4 of 6
Uh no. The mic would have to be connected by a non-HDMI input and then you can change the INPUT MODE of the MacBook Pro to either "Digital" or "Analog" depending on the cable used.
post #5 of 6
Ok, so the mic would have to be connected to the mac somehow.
post #6 of 6
Not necessarily ... what I meant was that the INPUT MODE setting on the AVR for the video source (ie. MacBook Pro) would have to be changed.
