AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › /// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\
/// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\ - Page 14
post #391 of 695
I don't even WANT to know how you figured out what a "magnet" was.
XBMC still has problems with some codecs and changes in resolution. You may be able to get specific help from someone in the XBMC threads.
Kalani gets all the credit for the batch file.
You have no idea how fortunate you really are. The first time we did this, the whole disc took 4 or 5 DAYS!
Enjoy.
Michael
post #392 of 695
Here is how...
post #393 of 695
So for those of us without access to a Blu-Ray burner, could someone possibly make one for me and I'll pay for the media? Or is there a way to run this off an external drive from a PS3?
post #394 of 695
Originally Posted by nickbuol View Post
Wow. I just unzipped the Batch-Blend.zip and opened the command file in Notepad. Nice work. As a former "DOS Monkey" I can appreciate the level on instruction and thought that went into that batch file and the commands to make all of the "magic" happen.
I will have to test it out tonight when I get home.
Thanks. smile.gif I did all the copying by hand when we were doing the final testing of the BD50, and after the second one, I was like "there MUST be a way to automate something this repetitive, fiddly and annoying!" LOL
I could have made the batch file a LOT more elegant, but it was late and I was tired. smile.gif It seemed to work fine, though, on the test directory structure I was playing with! Still, it should work fine as long as all the directories are named as they should be, and they're all nicely collected in one folder.
post #395 of 695
delete post
Edited by Unikym - 6/20/13 at 7:41am
post #396 of 695
First page explains how to do this.
post #397 of 695
Download of the full disc completed last night. Unpacked with WinRar, burned to a BD-RE with Imgburn, as per instructions on pg1. It plays flawlessly (so far) on my PS3 slim. Only had a chance to test a couple clips so far.
The menus are outstanding!!! Terrific work guys! Really amazing!
I'll continue seeding for a while, probably through the weekend at least.
Thanks again!!!
post #398 of 695
Has anybody gotten an "invalid disc error" when playing certain parts of the disc on PS3 (combined, then run through MultiAVCHD)? Each section plays except for Animation and Visual (both error out after the main menu with the "invalid disc" error). I downloaded each section separately, then followed the posted instructions to combine them into the full disc...
post #399 of 695
I d/l it yesterday, didnt take long. Im burning it on a dual layer BR now. Then it will be downstairs and blasting the neighbors!
On a side note, do you guys leave the Verify box checked in ImgBurn when you burn your copies? I do and it adds a lot of time to the burning process, like an extra 20-30 minutes. I wonder if I should uncheck that box, I've only had one disc that didnt work properly in my PS3, but it worked fine in a cheap LG player so I know the data was correct, just the PS3 didnt like it (it was only the Bass Demo part on a dual layer dvd also, so I didnt really mind)
On ANOTHER side note, does anybody else use an inkjet printer to print directly on to the discs? I missed out on a sale for 59 bucks, Staples had a printer that prints on discs, but by the time I realized it was on sale, it was sold out. If you print on the physical media, what printer do you have, or can you recommend a cheap printer for doing it? I like to buy the bluray cases, and print the labels and discs so they look as Pro as they really are. wink.gif
Sling.
post #400 of 695
I must be doing something wrong. I downloaded the "RARed_Reference_2_BD50.torrent.DELETE.TXT" file. I deleted the ".Delete.TXT" part of the file. I see on my desktop that the file does change from a Text file to a Turrent file. I uploaded the turrent file into uTorrent and doesn't download??
I then tried to uploaded the Reference 1 turrent tile and it works??
What am I doing wrong?
post #401 of 695
Sling.
The verify option seems to me to be a waste of time in this instance. The software can't do anything after the disc is burned. You playing it back on your PS3 is "verifying" whether it worked or not.
post #402 of 695
Thanks Leo, will nab it tonight!
post #403 of 695
Never mind. Finally got it to work.
Thanks again.
post #404 of 695
+1 Nothing to be done about it after the fact if the burn process did not work. I'm new to burning blu-rays, so I invested in a BD-RE (re-writable) disc. So, each time I'm ready to burn a new BD, I try it first with the BD-RE. I test it in my PS3, and if all is well, burn it again with a BD-R, so that I can re-use the BD-RE for the next project.
post #405 of 695
I verify just because I would rather know if the burn was sucessful. No surprised when trying to show off my system to my friends biggrin.gif
post #406 of 695
anyone else who burned the full BD50 notice that the vocals and the video on the REO Speedwagon clip seem to be off or is that just me? ive watched through most of the disk at this point and everything is great but that one clip just seems to not be synced. it sounds fine. just looks odd when they are singing
post #407 of 695
Smart move !
post #408 of 695
Excellent work guys, thanks for posting all the files, and than even better posting a method to combine them. Nice planning and execution on a great demo disc.
In relation to the batch file, this might not be the case for everyone, but I had to add VER>NUL as the 2nd line on my batch, in order to reset the errorlevel to 0. Might be cause I launched it a few times from the DOS prompt and it kept the error level from a previous run, not really sure, but it might be useful info for someone.
So the start of the batch for me is now.
@echo off
VER>NUL
set FULLPATH=%1
If I didn't have this, after all the instructions, it would exit before the first copy otherwise. Hope that helps someone.
Cheers,
post #409 of 695
Some of the music clips, and presumably the one you reference, isn't at the same frame rate as the movie clips. For some reason concert discs love using 29.97 frames per second instead of the 23.97 frames per second that movies are released at. My guess is that the frequent hopping between the two framerates has your equipment, for lack of a better word, confused.
post #410 of 695
that could very well be it. the Trace Adkins clip right after it was spot on and so was every other clip on the disk.
I watched the raw clip on my PC and it seemed much better. not really a big deal just through my mind for a loop.
post #411 of 695
Is there a way to get the original high quality artwork instead of downloading the picture from post #1? I downloaded that pic and printed but the resolution is pretty poor.
Thanks for putting this disc together. I have only been able to watch a few scenes but it is amazing from what I have seen!!!!
post #412 of 695
post #413 of 695
Thanks for all the effort! I finished download the whole blu-ray disc yesterday. I will try to burn it today, and will stay on uploading before my vacation hit next week!
post #414 of 695
Thanks L
Originally Posted by superleo View Post
Hi resolution images:
http://s295.photobucket.com/user/CastilloLeo/library/Reference%202%20Disc
Thanks Leo!!!
post #415 of 695
post #416 of 695
Dammit, now I have to choose between white and blue.
post #417 of 695
You're expecting us to do ALL the work for you?
post #418 of 695
Thanks to Kalani for creating and contributing a batch file.
I added the batch file on POST #9 that automates the coping and renaming process to create a full disc from the segments discs.
http://www.avsforum.com/t/1469192/reference-2-blu-ray-demo-disc-bd9s-bd50#post_23227080
Batch-Blend file
batch-blend.zip 37k .zip file
If you have questions or are unsure please ask.
Thanks for the batch file! FYI for anyone else that runs into this problem....the name for the folder where you have the disc folders can't be long. My folder was called Reference 2 Demo and it didn't work (even with quotes around it since there' s a space). When the batch file got to the last step before copying where it said "for the record you ran this batch file by typing:" it would truncate the folder name. When I renamed the folder to temp it ran fine.
post #419 of 695
Yikes, thanks for the catch!
Yeah, odd issues where paths with spaces are concerned (other than the per-disc folders themselves). I'll have to take a look and see if I can fix that.
Meanwhile, as long as the root folder (whatever that may be, the one where all the per-disc folders are located) has no spaces, all should work as intended.
post #420 of 695
I've burnt this twice to BD50 using the same method for all folders, and for some reason the Visual and Animation sections fail, although the disc plays fine and all the other sections work. I couldn't get them to work via USB either, so maybe just something weird with my download. I'll download the whole disc and see if that fixes it.
