AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › /// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\
/// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\ - Page 21
post #601 of 695
started file preparation for UL to NGs. Will do all 3 discs for convenient DL with NZB
post #602 of 695
Please post instructions for those of us who have no idea what you're talking about. ;)
Michael
post #603 of 695
Originally Posted by LastButNotLeast View Post
Please post instructions for those of us who have no idea what you're talking about. wink.gif
Michael
I will once everything is ready to go. PAR2 recovery set is saying 24 hrs to create..... ugh...
post #604 of 695
Michael
He's going to upload to News Groups (Usenet) so it can be dowloaded/searched via NZB (search engine)
Edited by shadowcaster - 9/26/13 at 2:36pm
post #605 of 695
Thanks. That helps.
We'll add the info/link/whatever to the info here when it's ready.
And, not to be a pig, are you going to do this for some of the other discs, too? :)
post #606 of 695
Yikes caper, why don't you just create Rar recovery (rev) volumes. Similar to Par and would only take a couple of hrs.
post #607 of 695
Thanks. That helps.
And, not to be a pig, are you going to do this for some of the other discs, too? smile.gif
An NZB file is very similar to a torrent file where, the client does all the heavy lifting (knows where to look for the rar files, etc, and downloads them).
The main difference between newzbin and torrent is: you download from a server with nzb, and not peer to peer, and no need to "seed" when you are done either.
Yes, I will be doing this for the other discs too. Actually, I decided last night to do the BestofRefDisc first, since it is on a much smaller scale, and will finish with Ref 2 and Ref 1.
I will likely only do a 5% recovery file set due to processing time. The computer I am using for this is also a HTPC for streaming to PS3, which is used to watch a movie or 2 on the weekend. 24 hrs to process 10% recovery files will knock out movie abilities for an entire day. The BestOf is almost ready to U/L. I watched Ironman 3 last night so I still have a tiny amount of prep left to do on it.
post #608 of 695
Here are the NZB and NFO files for newsgroups. It is still uploading so you may have to wait a few hours for the last few RAR files if you try and download immediately.
This is only for the BD50.
If the OP could post this on the first page with the torrent links, that would a better spot for it. Thanks.
Cheers
-Caper
RefDisc2_BD50_NZB.zip 667k .zip file
RefDisc2_NFO.zip 1k .zip file
post #609 of 695
One good thing about Newsgroups you sure can top out your download speed from those servers. I get about 3.7megabytes/sec which is fast for this small city, but nowhere near the speed of big city ISP packages. I sure would love to try that Google Fiber they offered for free out in Kansas City, Ive heard that tops out at over 100meg a sec on fiber to your house. eek.gif
post #610 of 695
I max out astra web at upwards of 8 Mbytes/sec, usually average 6.5 for downloads; and my speed test is about 11 ish (96 Mbits/sec) but I should be getting 175 on bell fiber op. With eastlink, I could max out my connection at 4.8 Mbytes/sec (about 30 Mbits/sec)
But yes, newsgroups/usenet is MUCH faster than any torrent I have downloaded.
Edited by caper_1 - 9/28/13 at 8:32am
post #611 of 695
post #612 of 695
Wanted to Say a BIG thanks to Superleo (OP) - this is a fantastic Disc! smile.gif
post #613 of 695
Can you play this with menu and all from a HDD in OpenElec/XBMC?
post #614 of 695
Some menus work with XBMC but others don't. Most clips work but some, mostly in the music segment, don't. If your in openELEC I suggest you do as I did: make symlinks with easy to read names in the top directory pointing to each clip in the STREAM folder. This way when you navigate to the directory you'll see the listing and be able to choose any clip from there. Just make sure to give the .m2ts extension to the symlinks so that XBMC recognizes them as playable files.
post #615 of 695
What software do you need to create a BluRay disc with menus, I would love to give it a go if I can get my head around it!
post #616 of 695
follow the link below for some explanation of what is needed beside lots of time.
http://www.avsforum.com/t/1475769/demonstration-blu-ray-discs-independently-authored#post_23440381
post #617 of 695
any chance of just buying a disk off someone ?
post #618 of 695
There are legal issues there.
post #619 of 695
FWIW, XBMC Frodo had issues video playback some of the clips on the 50GB disc, mostly in the Music section. These issues have disappeared with XMBC Gotham, all the clips playback without any stutter or skipping.
post #620 of 695
That's awesome... eagerly waiting for Gotham's official release then.
post #621 of 695
I've already cutover, the new collections management options is hard to go back from.
post #622 of 695
I know its still in beta, but how is it? A big jump over Frodo?
post #623 of 695
Perhaps you can discuss this on the XBMC thread.
post #624 of 695
The changes are mostly under the hood but playback is solid, it handles my BR and DVD MKV rips without any issues. I don't really use it for much else, preferring my Roku for streaming. The collection management is where I think it really shines. You can now edit sets and remove sets which is nice, no more 1 movie sets tongue.gif
You can run it side by side with an existing installation by installing it in another folder.
post #625 of 695
When using MuliAVCHD to convert to AVCHD structure do you load the AVCHD folder into image burn or just the BDMV and Cert folders?
post #626 of 695
I wouldn't do that, frankly. I'd keep the two folders named BDMV and CERTIFICATE, and just name the disc AVCHD.
), I'm not home so I can't check, but you may want to try changing your BDP's audio setting from "direct" to "source," or whatever the two options are.
That works for me, sometimes.
Did you ever figure out which way is correct?
post #627 of 695
No, since my BDP has been packed away to make room for a larger AVR. I use my HTPC for everything, now. Sorry.
But I used to just change it from one to the other, whatever it was. It usually worked.
post #628 of 695
I have an odd problem with trying to use MultiAVCHD to create a PS3 file from Reference Disc 2.
For some reason, the size of the folder is over 100GB instead of the original 45GB. I took a look at the files and somehow MultiAVCHD has made multiple copies of some of the Animation files (there are possibly others, I haven't gone through all of them). I'm assuming I can't just delete the extra files since they're numbered in order.
Does anyone have any idea why this is happening?
brad
post #629 of 695
On the Reference 2 disc, what song is it on the "Surround" main menu? It is female vocals.
post #630 of 695
From the Snow White and the Huntsman soundtrack -- Florence and the Machine: Breath of Life
