AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Looking for research info on subs
post #1 of 7
Well I just purchased my first set of klipsch speakers (KG 4.2 and KG 1.2v center) and they sound great, but my current sub (Yamaha yst-sw216) is basically useless with my new speakers. So my question is when looking for a good sub what do you look for?
post #2 of 7
To start, it would help if you were to answer some (ideally, most) of the questions in post #1 of this thread:
1. Your budget.
2. Size requirements/limits.
3. Room dimensions.
4. Primary uses.
5. Listening habits.
6. Appearance requirements.
7. Timeframe.
Otherwise, you might get recommendations for a $2,300 Seaton SubMersive HP, when all you've got is an 10' x 12' room and $250 to spend. wink.gif
Edited by eljaycanuck - 4/21/13 at 3:44pm
post #3 of 7
1. Your budget.
3. Room dimensions.
4. Primary uses.
7. Timeframe.
lol so true!
post #4 of 7
Just realized that my reply didn't directly address the OP's question... d'oh! redface.gif ...so here goes again:
I look for a combination of the following:
- a sub with good specs;
- a sub with positive reviews (both professional and non-professional);
- a sub that looks good (because aesthetics do matter);
- a company with a reasonably good (or better) reputation; and
- positive word of mouth from people I deem to be knowledgeable and trustworthy.
(The list is not in any particular order, and may not be exhaustive.)
Edited by eljaycanuck - 4/22/13 at 4:43am
post #5 of 7
Thank for the feed back guys.
I have been looking at the spec on subs but what numbers should I be looking for on subs? Watts.... Ohms.... Herts...... And what exactly do these specs mean as far as the performance?
post #6 of 7
Also what r your favorite brands and why?
post #7 of 7
The search function is your friend lol
